a116c rev03 bios dump please
Hometech a116c rev03 bios
Every donation made will go towards server fees and maintenance costs. -
Re: Hometech a116c rev03 bios
This bios does not work.Attached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
