HP EliteBook 725 G2 bios
  • Rhadu23
    • Mar 2021
    • 74
    • United Kingdom
    Any chance I can get a working bios for a HP EliteBook 725 G2?
    Attached is the saved dumps.
  • servis_null
    • Oct 2014
    • 82
    • Croatia
    Re: HP EliteBook 725 G2 bios
    Here you go
    • Rhadu23
      • Mar 2021
      • 74
      • United Kingdom
      Thanks for the reply, but I do not think it will work.
      My motherboard is: LICORICE 6050A2631301-MB-A02
        • 21133
        It will, the bios BID is M84
        • Rhadu23
          • Mar 2021
          • 74
          • United Kingdom
          thanks.
          will flash now
          • Rhadu23
            • Mar 2021
            • 74
            • United Kingdom
            still does not powers on.
            3.3v, 5v all present
            battery charges
            but does not power on
            • Lucasswai
              • Sep 2021
              • Tanzania
              Can i get a working bios for hp elitebook 725 g2 because all attached files right now are not working.
              • skazide
                • Jul 2015
                • 142
                • morocco
                elitebook 725 g2 bios locked
                can anu one unlock this for me plz
                • peste
                  • Dec 2016
                  • 12925
                  • ROMANIA
                  Re: elitebook 725 g2 bios locked
                  try..
                  • skazide
                    • Jul 2015
                    • 142
                    • morocco
                    thank you bro
                    • Crypts
                      • Feb 2023
                      • 20
                      • Algeria
                      Hello..
                      plz unlock me this HP 725 g2 sn:5CG5473XC1
                        • 21133
                        Originally posted by Crypts
                        Hello..
                        Your backup is`nt any good, it`s only 38.1KB ,make more backups and compare them to see if they are the same.
                        When you have a good backup try to unlock it with HPUnlocker https://www.badcaps.net/forum/troubl...23#post1622423
                        • Crypts
                          • Feb 2023
                          • 20
                          • Algeria
                          Thank you SMDFlea for the program , I will try it now. Since I don’t have much experience working with BIOS dumps, I wanted to ask if you could provide me with a dump file that has a high success rate.
                          I would like to point out that the file is not its origin
                          • Crypts
                            • Feb 2023
                            • 20
                            • Algeria
                            I would like to point out that the file is not its original size because it is compressed.or that the compressed file size is unusual.
                            • Crypts
                              • Feb 2023
                              • 20
                              • Algeria
                              I have an HP EliteBook 725 G2 and I encountered a problem with the BIOS. When I tried to extract the BIOS dump from the chip, the process failed and unfortunately the original IC got damaged.
                              I bought a new IC and tried to program it with a BIOS dump, but the laptop still doesn’t work.
                              Is there any solution or advice you can share to help me fix this issue?
                              Thank you in advance.
                                • 21133
                                bios. flash both https://www.badcaps.net/forum/troubl...79#post1540179
                                • STKR123
                                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                  by STKR123
                                  Greetings badcaps community,
                                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                  I learned that desoldering...
                                  10-29-2024, 06:03 AM
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                • Guest
                                  Elitebook 850 G5 BIOS bricked
                                  by Guest
                                  I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                  I assume the BIOS update failed, so I searched for the BIOS chip.
                                  I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                  However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                  Can the corrupted...
                                  03-24-2025, 01:21 AM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • lap-top123
                                  Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                  by lap-top123
                                  HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                  Hp Elitebook 850 G8
                                  ProdID 52W98EC#ABD
                                  SN# 5CG1458XQ7
                                  Mac-address #1: 84:14:4D:2C:4B:5B
                                  UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                  Mainboard : 6050A3216701-MB-A01(A1)
                                  08-20-2025, 07:28 AM
