z5wah la-b162p bios+ec chips
  • Markosgcx
    • May 2021
    • 30
    • Greece
    I want to find both of them in the motherboard.
    hello I'm new here and I'm new to technology apartment plus studies. I want to fix my laptop. Dead screen and doesn't respond to power button. I tried my best to turn it on then it opened it charged. The problem is the power button and the display. I want to find the bios chip so I can program it again with the idea of the power button and the display will work again. Plus when I turn on the motherboard the fan spins slow and if esc+fn keys pressed nothing corresponds. So I think the bios chip has some letters or binary codes changed. That's why nothing of the connected devices can actually work. But I don't know if it is the bios chip or the ec bios chip. I do it to learn or to fix my own things.
    If I can't have an answer I'll return this motherboard to the seller and take a new one.
  • Markosgcx
    • May 2021
    • 30
    • Greece
    Re: z5wah la-b162p bios+ec chips
    I hope I get an answer one day.
      • 20309
      Here`s the schematic for your board - http://www.s-manuals.com/motherboard/compal_la-b162p ,and heres the boardview - https://www.badcaps.net/forum/showpo...40&postcount=2 .The boardview will open with openboardview - https://openboardview.org/
      The bios chip is at U6 ,it will be silkscreened in white lettering on the motherboard,you can find its location using the boardview.There could be a second chip at U7. You will need an SPI bios programmer to make backups of the chip(s) .The CH341A is the cheapest programmer (+ you need a sop8 adapter),the best way would be to desolder the chip using a hot air station (not a hot air paintstripper gun) ,or using a soldering iron and a pick,run some solder across 4 legs and lift carefully with the pick,then do the other side. Alternatively you can use a SOP8 clip and avoid desoldering ,but the clips are not very reliable,they can be ok if used correctly.
      https://www.aliexpress.com/w/wholesale-ch341a.html
      Some of the ch341a black pcb version programmers need a voltage mod,its been discussed on the forum already.There aren`t any problems with the green pcb versions,if you can find one.
      EDIT: Here`s some alternative software for the ch341a,better than the included software
      https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
      https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
      If you decide to buy the programmer and post your backups then make sure to make at least 2 backups and compare the files using a hex editors "File Compare" function or some other method. Thats to ensure you made a good read.
      • Markosgcx
        • May 2021
        • 30
        • Greece
        So, it has only one chip and if U7 a second chip.
        New question, then why it has bios and ec bios? Or that chip actually is for both of them?
        And at U6 that chip is bios or ec or something else?
        I saw the schematic but I’ll take months to actually understand it.
        About the board view difficult to open the files due to lack of computer.
        I bought a programmer Ch341a and it’s the black one so Ill search more about it.
        I saw the mother board it’s has U6 chip.
        I think that’s the only chip I see with a trademark on it.
        Thank u so much.
        • Markosgcx
          • May 2021
          • 30
          • Greece
          Plus of course I will post my actions, till then I’m waiting for the programmer to arrive
            • 20309
            I checked and there is only 1 bios chip on this board at U6, so just make a backup when you get the programmer and post it here in a zip or rar attachment and someone will help.
            The EC is U28,theres some dedicated programmers to flash it, Vertyanov JIG ,SVOD3, SAS (vertyanov clone) .You can flash the KB9012/KB9022 with a CH341A though,(or you can buy a pre programmed chip on ebay)
            http://dangerousprototypes.com/docs/...ith_Bus_Pirate
            https://www.youtube.com/watch?v=GQGH6yZuXCc
            • Markosgcx
              • May 2021
              • 30
              • Greece
              I want to exclude the u28 chip so I’ll say that it’s ok because when I jump the pwr it turns on with fan spinning at low speed and keyboard external works.
              I’ll upload the U6 bios data then we see what happens.
              My question here is if U28 chip is messed up, what would do to the motherboard and it’s functionality?
              • Markosgcx
                • May 2021
                • 30
                • Greece
                Honest to god reprogramming kb9012 seems interesting but way advanced for me at the moment.
                • Markosgcx
                  • May 2021
                  • 30
                  • Greece
                  I read the article about EC, I’m sad to see that actually my board doesn’t work because of that EC U28.
                  I’ll try bios but I think that’s not the cause.
                    • 20309
                    The problem might not be with the bios or EC. You can try it anyway,when your progrmmer arrives.
                    • Markosgcx
                      • May 2021
                      • 30
                      • Greece
                      Alright. I’ll post every find I encounter. For now thank you.
                      • Markosgcx
                        • May 2021
                        • 30
                        • Greece
                        hello again, i brought the ch341a programmer and everytime i clamp the clip to the chip i get this message
                        Current programmer: CH341
                        ID(9F): 000000(Unknown)
                        ID(90): 0000(Unknown)
                        ID(AB): 00(Unknown)
                        ID(15): 0000(Unknown)
                        Thats phase one.
                        let me explain what i did.
                        Position 1 it starts with the red wire on the clip so i place the cable to the pin 1 (red)
                        i place the clip to the usb programmer and when i press read ic it shows me this message
                        whats wrong
                          • 20309
                          Make sure pin 1 lines up on the programmer on the 25xx side .Post a picture
                          • Markosgcx
                            • May 2021
                            • 30
                            • Greece
                            actually it was a faulty sop8 i went and changed it.
                            Here is what was read in the ic.
                            Now i want to know if these are correct.
                            Otherwise please upload the bios bin for z5wah la-b162p
                            • tesla2020
                              • Apr 2021
                              • 14
                              • Argentina
                              reprogramming the bios ec is not the same as reprogramming the bios? there should be no problems right? both are eeprom memories
                              Last edited by SMDFlea; 05-28-2021, 10:20 AM. Reason: https://translate.google.com
                              • Markosgcx
                                • May 2021
                                • 30
                                • Greece
                                From what I learned these days they get programmed differently but both can be programmed with the Ch341a programmer.
                                  • 20309
                                  here`s your new bios .
                                  • Markosgcx
                                    • May 2021
                                    • 30
                                    • Greece
                                    Flashed and the power button worked but only first time. The only change is that the fan stopped after it booted. But amazingly when it booted the fan had the correct speed but sadly in the end stopped.
                                    Any ideas?
                                      • 20309
                                      the bios is good, so just carry on the repair in the other thread you started .
                                      • Markosgcx
                                        • May 2021
                                        • 30
                                        • Greece
                                        Thanks moderator.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • inck243
                                          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                          by inck243
                                          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                          The BIOS...
                                          07-25-2024, 09:17 AM
                                        • thxd43
                                          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                          by thxd43
                                          Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                          I have a Lenovo ideapad 330S - 14IKB laptop.
                                          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                          02-23-2023, 08:37 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • Azurain
                                          Elitebook 840 G5 Bios Chip Soldering Question
                                          by Azurain
                                          I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                                          Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                                          04-14-2023, 06:58 PM
