NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
  • rares01
    • 19
    • romania
    #241
    doesnt work rc unlocker tryed and have black screen
    • hoaca388
      Badcaps
      • Jan 2022
      • 11871
      #242
      XXX
      • rares01
        • 19
        • romania
        #243
        worked thank you
        all work ok i can enter the bios but on startup i have the message system is booting in manufacture programm mode
        • ElPachanGuero
          • Mar 2023
          • Slovenia
          #244
          I also have a HP 840 G5 which powers on, Caps Lock blinks 5 times, then fan goes into fast mode
          Everything looks OK, all voltages are there except VCore (the regulator responsible for VCore doesn't get configured via SVID).
          S/N: 5CG8322JTC
          Thanks!
          • hoaca388
            Badcaps
            • Jan 2022
            • 11871
            #245
            S/N: 5CG8322JTC
            Thanks!
            HP EliteBook 840 G5 Notebook PC
            • ElPachanGuero
              • Mar 2023
              • Slovenia
              #246
              Thanks! I actually learned to rebuild the BIOS image by myself in the meantime. There was a problem with ME region. Bad checksum and structure was even detected by MEAnalyzer.
              The notebook works fine with my rebuilt image. Thanks anyway!
              On first start it actually behaved the same (caps lock flashes, fast fan) but after that the fan stopped and the system started to boot. So if anyone is facing the same issue and trying the repaired bios, be patient on first start after flashing new image.
              • NickParr666
                • Jun 2024
                I'm having the same problems as many others where the laptop fails to boot. Is it possible to clean the bios?
                Also, ME Analyzer reports Error: Detected CSE Extension 0x03 with wrong Partition Hash at FTPR > FTPR.man! on this file.
                Thanks .S/N:5CG9256VP8
                Last edited by SMDFlea; 06-18-2024, 02:29 PM. Reason: Added S/N:5CG9256VP8 to post.
                • ElPachanGuero
                  • Mar 2023
                  • Slovenia
                  #248
                  I did the same process (replacing the ME region with clean one) as I did in my case. However, I could not find the exact same version of the ME that you have in your BIOS image. So I used the same version that worked for mine.
                  Your version: 11.8.94.4494
                  I used: 11.8.95.4551
                  So don't be mad if the laptop self-destructs after booting with my rebuilt image
                  The ME Analyzer error is fixed with my rebuilt image. My error was exactly the same...
                  • NickParr666
                    • Jun 2024
                    Thanks ElPachanGuero and I won't be mad as the laptop is currently bricked
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 942
                      Hello Masters of Badcaps,
                      Need some help in fixing this bios that comes from a failed update. Now the laptop only flashes the capslock key and the power key.
                      HP Elitebook 840 G5 bios dump attached.
                      Many thanks!
                      Ray
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 942
                      Many thanks!
                      Ray
                      Hi SMDFlea, very sorry for having omitted this. SN# is 5CG9218GN1 - Thank you!
                      • danito
                        • Jun 2016
                        • 986
                        #252
                        try
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 942
                          Originally posted by danito
                          try
                          Worked perfectly, thank you so much Danito!
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 942
                            try
                            For some odd reason, every time I turn it off, it doesn't want to turn back on? I have to unplug the CMOS battery and the main battery to get it to start up again. Any thoughts?
                            Tks!
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 942
                              Both bios from failed update on a HP Elitebook 840 G5 SN# is 5CG9218GN1. When it failed, after only the caps lock key led comes on white and no response to power button. Thank you for any help!
                              • doktorkomputer
                                • Aug 2016
                                • 65
                                • Poland
                                #256
                                hoaca388 thx work but there is a problem with manufacture programming and it doesn't work from disk , danito work good.
                                • its service
                                  • Feb 2021
                                  • 141
                                  • india
                                  #257
                                  Hp elite book 840-G5
                                  Board part no : 6050A2945601-mb-A01
                                  S/n : 5CG91339GN
                                  Prod I'd : 3RF11UT#ABA
                                  Problem : endpoint security controller error showing
                                  I'll attached the both file main and ec file can clear this error
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11871
                                    #258
                                    S/n : 5CG91339GN
                                    https://www.badcaps.net/forum/troubl...55#post3310855
                                    • its service
                                      • Feb 2021
                                      • 141
                                      • india
                                      #259
                                      I have no idea sir how to edit can u anyone clear this error
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11871
                                        #260
                                        CCC
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • lap-top123
                                          Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                          by lap-top123
                                          HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                          Hp Elitebook 850 G8
                                          ProdID 52W98EC#ABD
                                          SN# 5CG1458XQ7
                                          Mac-address #1: 84:14:4D:2C:4B:5B
                                          UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                          Mainboard : 6050A3216701-MB-A01(A1)
                                          08-20-2025, 07:28 AM
