NM-B452_BIOS
  • Hasph
    • May 2021
    • 13
    • Israel
    NM-B452_BIOS
    Hi, guys
    Can someone pleas help me to patch the attached dump ?
  • 69d0b913
    • Mar 2018
    • 146
    • BR
    Originally posted by Hasph
    Hi, guys
    which model of your machine?
    • Hasph
      • May 2021
      • 13
      • Israel
      IdeaPad 320 (I think, no label )
      • 69d0b913
        • Mar 2018
        • 146
        • BR
        you need to send a new dump, do it with tl866 if you have one.
        • Hasph
          • May 2021
          • 13
          • Israel
          The 1 I've uploaded was done using TL866!
          • 69d0b913
            • Mar 2018
            • 146
            • BR
            make a new dump, this is giving error when creating the patch
            • Hasph
              • May 2021
              • 13
              • Israel
              I did the dump twice and compared them and they are identical
              I know that
              I was thinking the problem is that I dont know how to patch it
              Because I was getting an error
              Thats why I've asked for help
              • 69d0b913
                • Mar 2018
                • 146
                • BR
                I know that
                is giving error with your dump.
                • Hasph
                  • May 2021
                  • 13
                  • Israel
                  The autopatch is giving me an error
                  • 69d0b913
                    • Mar 2018
                    • 146
                    • BR
                    if using chip pliers, try to remove the chip and use with adapter, the pliers are no good.
                    • Hasph
                      • May 2021
                      • 13
                      • Israel
                      No, I've removed the chip and read it directly
                      I even tried a virgin dump from here, but the computers turns on but nothing appears on the scren (stays black)
                      • 69d0b913
                        • Mar 2018
                        • 146
                        • BR
                        but what's your problem? bios password? if it is, you can't just take a clean dump and put it in your machine, especially if it's lenovo, it doesn't work like that.
                        • 69d0b913
                          • Mar 2018
                          • 146
                          • BR
                          test this dump
                          • Hasph
                            • May 2021
                            • 13
                            • Israel
                            test this dump
                            This is exactly the same as I've uploaded (100% identical)
                            • 69d0b913
                              • Mar 2018
                              • 146
                              • BR
                              believe it is not! I made a junction between what you gave me from the link with your dump.
                              • Hasph
                                • May 2021
                                • 13
                                • Israel
                                You've maybe by mistake uploafed the wrong file
                                Because the 1 you've uploaded I've compared them byte by byte, and the is zero differences
                                • 69d0b913
                                  • Mar 2018
                                  • 146
                                  • BR
                                  I took this file "DUMP FILE" and made a union with its original dump. Just do the test on the machine and then comment here what happened.
                                  • Hasph
                                    • May 2021
                                    • 13
                                    • Israel
                                    Ok, I've tested it anyway and like I said its identical to the 1 I've uploaded
                                    Meaning I'm back at square one
                                    • Hasph
                                      • May 2021
                                      • 13
                                      • Israel
                                      @96d0b913, thanks for the effort, problem solved (took me long enough )
                                      Really appreciate it
                                      • 69d0b913
                                        • Mar 2018
                                        • 146
                                        • BR
                                        managed to do? what was the solution?
                                        • TimScrawn
                                          MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
                                          by TimScrawn
                                          Hi there,
                                          This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
                                          I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
                                          06-23-2024, 09:41 AM
                                        • plyanthony
                                          Razer Blade 15 no external display with attached screen disconnected from motherboard
                                          by plyanthony
                                          Computer in question : Razer Blade 15 2020 Base Model
                                          Model# RZ09-03286E22
                                          BIOS CHIP: WINBOND W25Q128BV
                                          What I'm trying to accomplish:
                                          I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
                                          What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
                                          W/Stock BIOS - 1.06:
                                          Disconnect the...
                                          02-01-2023, 09:35 PM
                                        • DARNO786
                                          M720Q Bios Password removal
                                          by DARNO786
                                          Hi guys i have an m720q bios which has a password on it.
                                          i tried Patching with the autopatcher but it gave an error
                                          it has also shows up with the 0199 error on boot
                                          Anybody know how i can patch this?
                                          Thanks...
                                          04-25-2024, 07:13 PM
                                        • Badpatch02
                                          Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                                          by Badpatch02
                                          Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                                          So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                                          I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                                          11-30-2024, 05:22 AM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
