NM-B452_BIOS
  • Hasph
    • May 2021
    • 13
    • Israel
    NM-B452_BIOS
    Hi, guys
    Can someone pleas help me to patch the attached dump ?
  • 69d0b913
    • Mar 2018
    • 146
    • BR
    Originally posted by Hasph
    Hi, guys
    which model of your machine?
    • Hasph
      • May 2021
      • 13
      • Israel
      IdeaPad 320 (I think, no label )
      • 69d0b913
        • Mar 2018
        • 146
        • BR
        you need to send a new dump, do it with tl866 if you have one.
        • Hasph
          • May 2021
          • 13
          • Israel
          The 1 I've uploaded was done using TL866!
          • 69d0b913
            • Mar 2018
            • 146
            • BR
            make a new dump, this is giving error when creating the patch
            • Hasph
              • May 2021
              • 13
              • Israel
              I did the dump twice and compared them and they are identical
              I know that
              I was thinking the problem is that I dont know how to patch it
              Because I was getting an error
              Thats why I've asked for help
              • 69d0b913
                • Mar 2018
                • 146
                • BR
                I know that
                is giving error with your dump.
                • Hasph
                  • May 2021
                  • 13
                  • Israel
                  The autopatch is giving me an error
                  • 69d0b913
                    • Mar 2018
                    • 146
                    • BR
                    if using chip pliers, try to remove the chip and use with adapter, the pliers are no good.
                    • Hasph
                      • May 2021
                      • 13
                      • Israel
                      No, I've removed the chip and read it directly
                      I even tried a virgin dump from here, but the computers turns on but nothing appears on the scren (stays black)
                      • 69d0b913
                        • Mar 2018
                        • 146
                        • BR
                        but what's your problem? bios password? if it is, you can't just take a clean dump and put it in your machine, especially if it's lenovo, it doesn't work like that.
                        • 69d0b913
                          • Mar 2018
                          • 146
                          • BR
                          test this dump
                          • Hasph
                            • May 2021
                            • 13
                            • Israel
                            test this dump
                            This is exactly the same as I've uploaded (100% identical)
                            • 69d0b913
                              • Mar 2018
                              • 146
                              • BR
                              believe it is not! I made a junction between what you gave me from the link with your dump.
                              • Hasph
                                • May 2021
                                • 13
                                • Israel
                                You've maybe by mistake uploafed the wrong file
                                Because the 1 you've uploaded I've compared them byte by byte, and the is zero differences
                                • 69d0b913
                                  • Mar 2018
                                  • 146
                                  • BR
                                  I took this file "DUMP FILE" and made a union with its original dump. Just do the test on the machine and then comment here what happened.
                                  • Hasph
                                    • May 2021
                                    • 13
                                    • Israel
                                    Ok, I've tested it anyway and like I said its identical to the 1 I've uploaded
                                    Meaning I'm back at square one
                                    • Hasph
                                      • May 2021
                                      • 13
                                      • Israel
                                      @96d0b913, thanks for the effort, problem solved (took me long enough )
                                      Really appreciate it
                                      • 69d0b913
                                        • Mar 2018
                                        • 146
                                        • BR
                                        managed to do? what was the solution?
