IdeaPad 3-14ADA05 Laptop - Type 81W0
Lenovo IdeaPad 3 15ADA05
hello can anyone help me blinking power led this is my backup bios
this is the info of the laptop
​PF2BFQTV
tnks in advanceAttached FilesLeave a comment:
I reach the goal and fix the computer... The SSD m.2 was corrupt... and for that i couldn't enter BIOS normaly. But with other m.2 it works fine!
So... if you have same problem, just change m.2
Please, see all my post to understand whats happened to me.
Thanks again for all of you who bring help without wanted nothing.
Hi, I need a BIOS file for Lenovo 15ADA05. The machine turns on without video, there is fan spin all voltages are present (3.3v, 5v, 19v) and the power button LED keeps flashing. It powered on once and gave TPM error message. I've tried the Novo button and disconnected CMOS to reset but to no avail. I suspect the issue is the on board RAM so if anyone can also provide me with a BIOS that has the on-board RAM disabled for troubleshooting as well I will also be gladly appreciative. Attached is a dump I was able to pull off the BIOS as required. Thanks in advance.
IdeaPad 3 15ADA05.
PN: 5B20S44266 (Not sure if this is the board serial number but this is what I got from the sticker on the RAM slot)
Model: GS550
https://www.badcaps.net/forum/troubl...11#post3237947Leave a comment:
IdeaPad 3 15ADA05.
Model: GS550Attached FilesLeave a comment:
I already try that, even i explain all in post 194
All serial numbers that i have is from the webpage wich sends me the QR code from laptop label. Pictures attached in post 193
The NOVO button that you means does not work, when I select BIOS option, it does not get in BIOS, just go ahead loading OS, and stuck there.
I will try with another M.2 SSD just to see what's happening...Leave a comment:
So... i could never go to BIOS... thats why i think there is a problem and wanted to test with another BIOS.... I don't know if there is any keyboard combination to Activate something which let me in BIOS.
I don't think that another thing is wrong... even i can't take out RAM couse they are SMD and soldered.
Thanks anyone for your help!! I hope this case could help others!
Namaste!Leave a comment:
Woow QR works and tell me wich computer ir... because there is no label just the ones in attached photo.
This computer is a IdeaPad 3 14ADA05 81W0 PN: PF2PRW41 MTM: 81W000MUAR
With AMD Ryzen 3 3250U and DDR4 4GB
Just for understand, why is important this numbers?? I really like to understand that... thanks for any kind of support!!
PD: my client was so awful taking care this computer... like you see in inside back plate.
Just for refresh my problem...
The computer starts with Blue Screen Error... Client sends me a pic showing the Recovery instance with error code 0xc0000001
When I get it, i looked inside and saw that i was full of dirt. So i cleaned it.
Then I try turning on, and it allway get stuck "Loading Windows" in LENOVO Logo stage.
So i wanted to see BIOS, and pressing F2 or FN+F2, nothing happends, just LENOVO Logo without any loading, gettin stucked.
Looking for internet it says that this notebook comes with NOVO Button... i pushed it, Menú appear, but i have the same problem... BIOS is not working, just the LENOVO Logo. When I try another option, is the same... just goes to LENOVO Logo and get stucked there.
When I take off SSD m.2 the computer says:
"Verifiying shim SBAT data failed: Security Policy Violation
Somthing has gone seriusly wrong: SBAT self-check failed: Security Policy Violation"
So I realise that there is SecureBoot ON.
PD: my client was so awful taking care this computer... like you see in inside back plate.Leave a comment:
I'm sorry but i didn't follow... Soyo SY-7VBA133U points to another user asking for correct bios, do you reffer to DMI copy ? from what i have been reading DMI doesn't male power led blinking but windows uefi key and other issues right ?
Edit: i think i got the problem, when i write BIOS and next when i read it results are the same. I am using clip and i think i will need 1.8v adapteur am i right ?
I attach datasheet.
You have to see first which voltaje is working... may be chip could works with other voltages but better use the intended for. Even you can test 8 pin for seeing voltage from the board.
Hope could be helpful!Attached FilesLeave a comment:
Edit: i think i got the problem, when i write BIOS and next when i read it results are the same. I am using clip and i think i will need 1.8v adapteur am i right ?Leave a comment:
you have everything you need at post # 217..
Please attach your backups directly to your post in a zip or rar.Leave a comment:
Hey there, have tried all BIOS on recommended posts, but still Ideapad3 15ADA05 has power blinking light with no image. SN is PF24W3TN, MTM 81W100EDPG, model name 81W1 and i did a bios dump before trying other versions. Can anyone point me in the right direction ?Badcaps Electronics Repair Forum & Schematic SearchLeave a comment:
This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by joven016Problem is blinking power led only
i don't know exactly if it's s145-15igm or s145-14igm
have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
Already tested some of posted bios here
S145-14igm - success but invalid serial and not booting on OS
S145-15igm - success with serial and some other info in bios but still not booting on OS
already tried installing new windows but always booting on bios setup
windows installer flash drive detected on...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
- Loading...
