how to flash macbook 2018 via bootable usb
  • HSBunlock
    • Mar 2021
    • 30
    • UK + PAK
    apple will remove activation lock but its still showing activation lock now i will try to reinstall macos via bootable usb but when i press (OPTION) button the drive not showing which i create bootable, i have 2018 macbook pro 15inches
    is that posible?
  • HSBunlock
    • Mar 2021
    • 30
    • UK + PAK
    Re: how to flash macbook 2018 via bootable usb
    is that posible?
    • sinidi48
      • Sep 2019
      • 10
      • france
      apple from 2018 to 2020 it blocks the usb port your mac cannot read the usb key
      • HSBunlock
        • Mar 2021
        • 30
        • UK + PAK
        oky thanks
        • curiositymaster
          • Apr 2021
          • 45
          • Nigeria
          Originally posted by HSBunlock
          oky thanks
          You can actually enable external bootable disks if you have access to the recovery and administrative password.
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • netboy69
            Macbook Pro 15, A1990 2018, showing recovery not dfu, error 9 when restore, HELP
            by netboy69
            Hi to all i have a faulty a1990 from 2018, no liquid damage, died during update, now on configurator i see recovery not dfu, and i get error 9. caps around u7701 show short after removing u7701 and shorted caps still short. can any help....
            02-07-2024, 04:34 PM
          • robka
            MacBook Pro 2018 - A1990 Dead - not charging - only 5V
            by robka
            my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
            I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
            The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
            After that the Macbook was dead. It isn't charging anymore.
            The USB-C Port where the charger was plugged is burned. Also The Cable and the...
            03-02-2024, 02:58 PM
          • MyronViegas
            MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
            by MyronViegas
            Hey guys,
            I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
            Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
            10-06-2025, 08:45 AM
          • ekozeko333
            by ekozeko333
            🧠 What I’ve Done So Far
            Flashed...
            06-21-2025, 02:48 AM
