Lenovo Thinkpad L15 (CPU 10th Gen) Supervisor Password
  • ssdd
    replied
    I am able to read the EC for L15 Gen1 with SVOD4. Can someone assist me on how to remove supervisor password. I have tried yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4 and it did not work for me.
    Attached is my EC dump.
  • ibo
    replied
    Originally posted by farouk_1994
    Re: Lenovo Thinkpad L15 (CPU 10th Gen) Supervisor Password
    Hello sir can you upload video or picturs how to read the i/o on this model using
    svod4 please
    https://www.youtube.com/watch?v=dK4lJMtNS-Y&t=315s
  • ymifdal
    replied
    Please help with connection of RT809H.
    With auto-ISP it shall connect without problem?
    RST cable shall be connected?
    There is somwere 10K resistor to switch to able programming?
    I made schematic fot ISP/JTAG, can someone confirm?
    reupload with small image
    Could somebody confim this is working with Lenovo L15 gen 1 ?
  • Vesko356
    replied
    Vesko,
    Author of this topic ask about password and how to recover it. Seems he made a post in wrong part of forum, as he didn't made bios request, but password removal help.
    I continue discussion of how to remove password.
    I didn't upload bios file at all, so i think this is missunderstanding.
    This topic is about Lenovo Thinkpad L15 Supervisor Password removal, if your request is about this model OK, if not you are off topic here, that's why you must provide the data I've asked for as per the rules.
  • rbvndonh
    replied
    Vesko,
  • Vesko356
    replied
    Read the rules before posting
    Provide the full machine model number, serial number (or Service tag, SNID), EC chip model number, and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
  • rbvndonh
    replied
  • Vesko356
    replied
    Originally posted by dhan
    please remove password of this EC.
    ryzen build
    nm-c741
    Read the rules before posting:
    You MUST:
  • dhan
    replied
    ryzen build
    nm-c741
  • 7Ironhide7
    replied
    Originally posted by Redion
    So did anyone had any luck using SVOD4 or vertynov?
    From SVOD i keep getting empty reading and cant write or erase or verify.
    Has anyone had any luck?
    SVOD and VERTYANOV are proofreading the firmware, ABOVE POSTED A CLEAN, READING CONSISTS IN THE CORRECT CONNECTION !!!!!
  • adiasterix81
    replied
    how did u read the chip? through the keybord cable or desolder it ?
  • hardwareserwis
    replied
    will i read svod 3.0 ?
  • Redion
    replied
    Originally posted by diego2019
    hello friends, first you have to do is update your svod4, ask the manufacturer for that, second the steps are in the note, and third you have to connect the battery and charger. I leave the clean files of the ec.
    Why is the extracted EC file not 256kb?
  • hardwareserwis
    replied
    does reading from svod 3.0 work for you ?
  • diego2019
    replied
    Can you please upload full config and connection from SVOD?
    I will try to connect using RT809H
  • just_bios
    replied
    hey guys..
    which programmer supports npce68bpa1dx..? can u pls give me a link..?
  • rbvndonh
    replied
    I found a Vertyanow successor NM-C631 KB_pins=40 LEFT DOWN 05MM FLASH=256 JENK=7 TCK=13 TMS=11 TDI=14 TDO=17 CHIP=NPCE68APA0DX 0x0FE2201F (evserv)
    This will allow to connect using RT809H?
  • rbvndonh
    replied
    yes, with svod4, you have to update to be able to read that ec, it is also 256 not 128. in the end I was able to do it.
  • rbvndonh
    replied
    No solution for RT809H?
    Can you post picture with pinout connection on motherboard?
  • r12x2
    replied
    i have the latest update qs you can see in the picture and i upload the file that i got after reading the io
    Try to read it with the battery attached
  • lrservicios
    Lenovo Thinkpad X12 Detachable 1st GEN Supervisor Password
    by lrservicios
    Hi !
    I have a Lenovo Thinkpad X12 Detachable 1st GEN with Supervisor Password - Type 20UV-S2Q100 Serial Number: PW-01NB9P - PW01NB9P
    I attach Bios 2 Chip reading Bin, please can you try to clear it for me ?...
    05-02-2025, 12:35 PM
  • AppleLover123
    Lenovo Yoga X380 22LH Supervisor Password removal
    by AppleLover123
    Hey guys,
    have a laptop here that has a supervisor Password (dump in Attachements).
    Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
    the laptop works but everytime it wants me to type a supervisor password i never set.
    I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
    Anyway i wanted to ask what of the two chips is the ec bios because on the left...
    04-17-2025, 03:42 PM
  • kuraimangetsu
    LENOVO ThinkPad E14 E15 JE442 NM-E211 bios supervisor password remove
    by kuraimangetsu
    Hi
    LENOVO ThinkPad E14 E15 JE442 NM-E211 bios supervisor password remove...
    03-31-2024, 07:25 AM
  • RMDUiFT
    Should I buy a Lenovo Thinkpad E495 with bios password?
    by RMDUiFT
    Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
    I have a few questions:
    • If I would buy this laptop and have
    08-25-2024, 09:00 AM
    Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E14 Gen 2 (Intel) boardview and ThinkPad E14 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-07-2024, 05:20 AM
