Samsung 910S3K TACOMA-131 REV 1.1 BA41-02436A GCE BIOS DUMP
  • repairplus
    • Feb 2021
    • 39
    • Republic of Korea
    MODEL : Samsung 910S3K
    PCB Ver: TACOMA-131 REV 1.1 ( BA41-02436A GCE )
    BIOS Ver : P04RDC
    Help me update the BIOS DUMP
    • 22279
    Re: Samsung 910S3K TACOMA-131 REV 1.1 BA41-02436A GCE BIOS DUMP
    post your bios backup
    • repairplus
      • Feb 2021
      • 39
      • Republic of Korea
      Many thanks!
      • BootLoader1
        • Aug 2020
        • 70
        • Poland
        Version P10 + Win Key
        • repairplus
          • Feb 2021
          • 39
          • Republic of Korea
          Thank you.
          However, the screen is bad.
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
