La-9984p bios
  • Techtiger
    • Oct 2014
    • 1602
    • france
    La-9984p bios
    hello Guys
    i need BIOS for Dell la-9984P VBW11 Rev:1.0 A00
    i have flashed with post #2 (https://www.badcaps.net/forum/showth...light=la-9984p) file error
    i have flashed with post #4 ( https://www.badcaps.net/forum/showth...light=la-9984p)
    but no luck
    thanks in Advance
    • 21692
    Re: La-9984p bios
    Post your original bios backup.
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Re: La-9984p bios
      SMDFlea Original bios was deleted by another Tech
        • 21692
        Re: La-9984p bios
        do you have the service tag
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Re: La-9984p bios
          No service tag not available ( sticks behind is not available) it’s Dell 17r 5737
            • 21692
            Re: La-9984p bios
            These models use the same bios - Inspiron 5537/5737/3537/3737 .
            Attached is the virgin bios extracted from the A12 update.
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Re: La-9984p bios
              Thanks for the Bios i will update you
              • mkdj
                What should I do after having flashed a BIOS?
                by mkdj
                Dear all,
                I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
                Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
                09-09-2025, 09:45 AM
              • Loli Popu
                DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                by Loli Popu
                Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                12-13-2024, 03:28 AM
              • drux
                Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                by drux
                I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                These models have AMI/Aptio BIOS.
                Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                11-03-2024, 01:18 AM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
