Need a BIOS dump for toshiba l50-a-119
  • slujeben
    • Mar 2018
    • 10
    • Bulgaria
    Hello i need a dump for :
    Toshiba Staleite l50-a-119
    part no: PSKJQE
    MB: VGFG MB rev.2.1
    • 22287
    Re: Need a BIOS dump for toshiba l50-a-119
    post your bios backup
    • slujeben
      • Mar 2018
      • 10
      • Bulgaria
      Here is it. but i'm not sure for backup is ok
        • 22287
        There are 2 bios chips on the board, 2 and 4MB .Here`s the 2MB ,program it and check if the board starts up.If it doesn`t then post your 4MB backup.
        • slujeben
          • Mar 2018
          • 10
          • Bulgaria
          here 4 mb bios
            • 22287
            here.
            • slujeben
              • Mar 2018
              • 10
              • Bulgaria
              Thank you, i still have a black screen, all voltage is check....
              I using "NeoProgrammer" with CH341A mini programmer
                • 22287
                Both bios were extracted from the official update,you won`t get a better one .The problem is 100% somewhere else. If you want further help with it then start a new thread in the main laptop forum, post your voltage measurements on all large grey coils .
                https://www.badcaps.net/forum/forumdisplay.php?f=23
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers 😀,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  💀 Problem:😅
                  - Device shows “Administrator Password”...
                  08-07-2025, 04:54 AM
                • DProf.
                  TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                  by DProf.
                  High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                  Toshiba Dynabook T55/AB, PT55ABP-BJA2
                  MODEL NAME. Satellite L50-D series
                  P[ART NO PS57MN-00600R
                  Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                  09-26-2024, 04:30 AM
