Hp elitebook revolve 810 g3 clean bios dump
  • mnciks11
    • Aug 2019
    • 347
    • south Africa
    Hello guys, i have an Hp elitebook revolve 810 g3 with a bios password...
    So what i did was, i tried to wipe the password but i failed, now i cant go back to where it was from the start, it turns on and no display after i tried to clean bios...Please help guys below it the original files
  • peste
    • 13924
    • ROMANIA
    Re: Hp elitebook revolve 810 g3 clean bios dump
    try..
    • mnciks11
      • Aug 2019
      • 347
      • south Africa
      Originally posted by peste
      try..
      Bro i love you so much man.... it working damn
      did you clean the ME region or you used the hp bios tool?
      • peste
        • 13924
        • ROMANIA
        use the HxD program, compare bios ...
        • mohammed mohan
          • Nov 2017
          • 210
          • F12
          thank you
          Mohammed Mohan
          • dennis akumu
            • Mar 2018
            • 113
            • kenya
            Ineed this file my machine has no display
            ovation mb 14209-1.plizz any body
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              Here's your New BIOS, try it and give me results.
              Serial Number: 8CG7201P91.
              all donations are welcome,
              • dennis akumu
                • Mar 2018
                • 113
                • kenya
                here's your new bios, try it and give me results.
                Serial number: 8cg7201p91.
                no display still.the fun is rotating in full speed.do you have 2mb file ive attached my 2mb.
                • hardware1
                  • Sep 2021
                  • 2949
                  • N/A
                  No, I don't have it. But you can try the file at Post #1, it contains (16MB & 2MB). It's locked with a Password, but if it works for your device we can remove the password after that.
                  • 4G comm
                    • Sep 2021
                    • 53
                    • kenya
                    try..
                    working bin thank you from kenya
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
