Acer Aspire E5-774 bios request
  • Rhadu23
    • Mar 2021
    • 74
    • United Kingdom
    Can I please have a working BIOS for an Acer Aspire E5-774 N16Q5 (E5-774G-546F)?
    Old dump attached.
    Thank you in advance.
  • peste
    • Dec 2016
    • 13653
    • ROMANIA
    Re: Acer Aspire E5-774 bios request
    Old dump attached.
    try..
    • Rhadu23
      • Mar 2021
      • 74
      • United Kingdom
      Originally posted by peste
      try..
      not working....
      now it does not power on at all ...
      • peste
        • Dec 2016
        • 13653
        • ROMANIA
        not working....
        try...
        • zarabota
          Acer Aspire A717-71G - problem BIOS with keyboard
          by zarabota
          I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
          However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
          09-03-2025, 01:58 AM
        • ebyte64
          Bios request for Acer P214-52-58CH
          by ebyte64
          Good day.
          I would like to request a bios for the following laptop?
          Model: Acer P214-52-58CH
          Model No: N19Q7
          S/N: NXVLHE0H11204BA27600
          SNID: 11201936276
          Symptoms: Laptop powers on but no picture on screen.
          I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
          09-25-2024, 05:59 AM
        • Danfay
          Acer Aspire 3 A317-51G Request Bios in .bin file
          by Danfay
          Hello, I have an Acer Aspire 3 A317-51G, with a QH128AHIG XMC chip.
          Due to a problem when I turn off the computer, I tried to upgrade the bios through Windows (10), this is the only possibility to update in Acer. Unfortunately, something went wrong . The laptop starts but I can't even access the Bios. I searched for a long time, without success, for the Bios version in .bin file .
          The last functional Bios version was: InsydeH20, Rev. 5.0, Version 1.09 .
          So I updated to version 1.11, which apparently either went wrong or is not functional.
          Does anyone...
          09-25-2023, 02:57 AM
        • NecroFlex
          Acer Aspire 1 A115-32-C28P BIOS needed please
          by NecroFlex
          I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
          I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
          I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
          02-11-2025, 08:51 AM
        • jhanra
          acer aspire k50-10 bios
          by jhanra
          gud day masters
          i have acer aspire k50-10 no display, fan spins 10 sec. then off
          i dont know if this is the orig bios cause someone work on bios
          acer aspire k50-10
          snid 63409414776
          board DA0ZRWMB6G0 REV G
          i5 with nvidia graphics
          i tried all the posible bios for this board but no luck
          i think bios is for same board but for different model?
          hope someone helps
          thanks!...
          06-11-2024, 08:54 AM
