simple question
  • saidbe
    • May 2017
    • 42
    • Chilo
    simple question
    I have a simple question:
    I have two laptops of same type Toshiba z30 , one without bios password the second with password. Can I use the programmer to copy from one bios to the other?
    Does that also apply to all brands?
    Thanks in advance.
  • AAAC
    • Jan 2020
    • 458
    • Mexico
    Re: simple question
    Q1: Can I use the programmer to copy from one bios to the other?
    A1: You will be just copying the BIOS chip contents from computer #1 to #2, the password is stored in EC/KBC chip, so computer #2 will remain locked with bios of unlocked #1 laptop.
    Q2: Does that also apply to all brands?
    A2: It depends on bios manufacturer, the procedure may work for some models which store the password in bios chip.
    • saidbe
      • May 2017
      • 42
      • Chilo
      Re: simple question
      Thanks,
      Are the passwords always stored in the EC/KBC chip?
      Even the second and third generations of laptops?
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        Re: simple question
        In old Dell Latitude laptops the password is stored in EEPROM chip, then they increased the security and introduced MECxxxx ec/kbc chips where the password is now stored. In old Toshiba laptops that use Challenge/Response Code, the password is stored in EEPROM and in BIOS chip, but since bios has a checksum if you modify contents the laptop won't POST.
        With UEFI, some passwords are stored in UEFI Variables in bios chip, sometimes in plain-text, XORed password or a hash of the password, other times also stored in EC/KBC chip.
        I'll say that every model is unique, you can not categorize them into uProcessor generations, as from time to time a model will not fit in as to where the password is stored.
        Just my opinion.
        • saidbe
          • May 2017
          • 42
          • Chilo
          Re: simple question
          Thanks for your reply.
          Is there a way or a tool to find out this information? Which bios to duplicate which ones not.
          • AAAC
            • Jan 2020
            • 458
            • Mexico
            Re: simple question
            There's probably a way, by making a list.
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • Caimano
              Need to copy DMI info for HP ProBook 650 G2 Bios
              by Caimano
              UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
              Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
              01-03-2024, 05:19 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
