A1398 EMC2745 -clean me please
  • djems3
    • Nov 2014
    • 32
    • United Kingdom
    Hi can i have a cleaned me region and password please.
    Thank you.
  • peste
    • Dec 2016
    • 13451
    • ROMANIA
    Re: A1398 EMC2745 -clean me please
    Thank you.
    try..
    • djems3
      • Nov 2014
      • 32
      • United Kingdom
      Thank you for your help .Doesn't start with this file .Fans spinning for 4-5 sec and goes off.
      • peste
        • Dec 2016
        • 13451
        • ROMANIA
        try..
        • djems3
          • Nov 2014
          • 32
          • United Kingdom
          Same.I just would like to add more info board is 820-3662-03.Processor 2.0 GHz Core i7 (I7-4750HQ).S/N in my original bin file doesn't match to this Processor . It match to 2.3 GHz Core i7 (I7-4850HQ) ,this mean my file is not original it been changed.All three S/N are different.Under palmrest,back cover and in backup file.Label on the board is missed .What could i do now?Please for any suggestions please.
          Thank you.
          • peste
            • Dec 2016
            • 13451
            • ROMANIA
            Thank you.
            also post the serial number S/N on the case ...
            • djems3
              • Nov 2014
              • 32
              • United Kingdom
              Right EMC is 2674 ,ME293LL.I wrote dump it start but is very slow ,
              i have errors on diagnostic menu
              reference code:PPM002
              additional reference code :PPM003,PPM004
              Do i have to change all memory ic's or still my wrong bios?
              Thank you.
                • 21692
                What is the serial number on the back cover. Palmrests do get replaced as does the bios,the serail on the back cover is the one most likely to be the original
                • djems3
                  • Nov 2014
                  • 32
                  • United Kingdom
                  C02LP0Z0FD59-back is replacement as well.Can't by rigth serial .This match with 2.6 GHz Core i7 (I7-4960HQ).
                  • peste
                    • Dec 2016
                    • 13451
                    • ROMANIA
                    try..this..
                    • djems3
                      • Nov 2014
                      • 32
                      • United Kingdom
                      Doesn't start with this bin .Thank you.
                      • Bisketti
                        Hp 13-aq me region needs to be cleaned
                        by Bisketti
                        Hi any help appreciated. I just need this bios Me region cleaned.
                        Attached is orig dump. The full model is Hp13-aq0500sa serial number 8CG939C4Y6.
                        Product id: 6TC75EA#ABU
                        Thank you....
                        04-09-2023, 09:47 AM
                      • tom3k
                        Dell Precision 5540. Need clean ME Region
                        by tom3k
                        Laptop: Dell Precision 5540
                        MB: LA-H331P Rev: 1.0(A00)
                        Hi.
                        I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
                        After extracting my BIOS in FIT the ME Region size is 7565 KB.
                        However the ME Region files I fouud online are 11688 KB in size.
                        Can someone help me find he correct clean ME Region?
                        Thanks!
                        Code:
                        ║ Family │ CSE ME ║
                        06-28-2025, 12:34 PM
                      • Adenitz
                        Clean ME region - a bit of theory
                        by Adenitz
                        Hello laptop repair experts,
                        can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
                        I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
                        What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
                        Recently, I had a two cases where laptops (one is Lenovo Idepad...
                        10-21-2023, 04:44 AM
                      • Lexsmash85
                        Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
                        by Lexsmash85
                        Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
                        Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
                        USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
                        08-06-2025, 03:41 AM
                      • reessi
                        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                        by reessi
                        Hello:
                        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                        I started on the ACER:
                        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                        10-29-2024, 11:31 AM
