Hp 13-aq me region needs to be cleaned
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Hi any help appreciated. I just need this bios Me region cleaned.
    Attached is orig dump. The full model is Hp13-aq0500sa serial number 8CG939C4Y6.
    Product id: 6TC75EA#ABU
    Thank you.
    Last edited by Bisketti; 04-09-2023, 09:59 AM. Reason: Apologies I though I attached the orig dump.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Hp13-aq me region needs to be cleaned
    Upload the dump, also your factory one if you have it, device serial number, full model name ...
    Become a Badcaps supporter
    Thanks to all supporters.​
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      Re: Hp 13-aq me region needs to be cleaned
      Thank you.
      Here you are:
      • Destroyer-Br
        [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
        by Destroyer-Br
        I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
        When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
        If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
        After flashing it, the board does not power on — no signs of life.
        I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
        11-23-2025, 02:48 PM
      • tom3k
        Dell Precision 5540. Need clean ME Region
        by tom3k
        Laptop: Dell Precision 5540
        MB: LA-H331P Rev: 1.0(A00)
        Hi.
        I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
        After extracting my BIOS in FIT the ME Region size is 7565 KB.
        However the ME Region files I fouud online are 11688 KB in size.
        Can someone help me find he correct clean ME Region?
        Thanks!
        Code:
        ║ Family │ CSE ME ║
        06-28-2025, 12:34 PM
      • Adenitz
        Clean ME region - a bit of theory
        by Adenitz
        Hello laptop repair experts,
        can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
        I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
        What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
        Recently, I had a two cases where laptops (one is Lenovo Idepad...
        10-21-2023, 04:44 AM
      • Lexsmash85
        Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
        by Lexsmash85
        Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
        Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
        USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
        08-06-2025, 03:41 AM
      • reessi
        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
        by reessi
        Hello:
        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
        I started on the ACER:
        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
        10-29-2024, 11:31 AM
