lenovo ideapad 700-15ISK bios repair needed
https://www.badcaps.net/donateComment
I will explain to you how I had this problem I wanted to do the online update of my LENOVO IDEAPAD 17ISK laptop, the update went well and when restarting the screen remained black, the fan turns normally but impossible to restart it normally. I pressed the reset button with a paper clip I enter the bios as you can see in the attached photo, but impossible to restore or do anything else. Thank you for your help
1 PhotoComment
Does anyone know what the problem may be ?
lenovo ideapad 700-15isk , when the charger is connected the power indicator lights up and fans spin for a couple of seconds and turn off , the light is still on , and the power button does nothing and the chipset heats up, i have flashed the bios images that were given in this thread and it has done nothing, any suggestions ?
Motherboard model: LOL SKL MB
15221-1
448.06r01.0011
Bios chip: MXIC MX 25L12873FComment
15221-1
448.06r01.0011
Bios chip: MXIC MX 25L12873FDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by joven016Problem is blinking power led only
i don't know exactly if it's s145-15igm or s145-14igm
have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
Already tested some of posted bios here
S145-14igm - success but invalid serial and not booting on OS
S145-15igm - success with serial and some other info in bios but still not booting on OS
already tried installing new windows but always booting on bios setup
windows installer flash drive detected on...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
by BOGOSY77Lenovo IdeaPad Slim 3 15ABR8 NM-F031 Rev 1.0
KS486/KS489/KS586/KS681 NM-F031 REV1.0
S/N: PF4YX6CX
Can someone clear or rebuild this one, no display, no fan, only power button on, after 2 hours keyboard back light blink once, that it.
Thank you so much....-
- Loading...
