lenovo ideapad 700-15ISK bios repair needed
Every donation made will go towards server fees and maintenance costs. -
Re: Lenovo ideapad 700-15ISK BIOS+ EC NEEDED
Hello, I have a problem with a laptop MB LOL SKL MB 15221-1 448.06r01.0011 Lenovo 700-15ISK is a black of screen, I suspect a corrupt bios, unfortunately I uploaded all the forums, vlab, and elvikom but there is no voltage on the processor at all, on I am asking you to repair my bios
Greetings.
Helloo! My ideapad 700 has no display after sleep mode. Was the reason in the bios?Comment
İdeapad 700-15ISK
hello friends lol skl mb 15221-1m 448.06r01.001m I tried all the bios files in the bios required shared topics, I could only get the image with the attached bios file, after a while it started giving "a7 me fw downgrade request mespilock failed" error, I made clean me to the same file, but I couldn't get a picture after clean me, if anyone can help I would be very grateful, thanks in advanceComment
Re: İdeapad 700-15ISK
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
yes, the file in the 11th message is already I was able to take an image with it, but after a while I started to get such an error, it may be in ec, my problem, but I can not program ec, it gives an error, let me look a little more thanksComment
Re: lenovo ideapad 700-15ISK bios repair needed
The bios has been tried, there is no problem, but when I say turn it off, the power led does not turn off, it turns off after 3 minutes. Thanks for your interest.Attached FilesComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello, thank You very much for this forum thread. Helped my laptop work.
I have a questions for You:
Could you tell me what offset should be copied to the new bios in HxD
- copy laptop serial numbers, laptop data. I found (begin offset 00801000 to 008011F0) but i'm not sure its correct part
- windows key
I'm sorry if the question is trivial for you, I just bought the programmer yesterday and after the 5th attempt I managed to restore it to work (black screen). This was done thanks to a batch shared by @pesteComment
- windows key
Windows key : Find : 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
Need help with Lenovo 700-15isk bios
I am trying to clean ME region but Intel FIT wont open the .bin file.
Unable to open file: C:\Flash Image Tool\WIN32\len70015isk.bin. Reverting to default configuration.
Can someone else try to clean me region for me.
Lenovo 700-15isk
LOL SKL MB
15221-1
448.06R01.0011Attached FilesComment
Re: Need help with Lenovo 700-15isk bios
Lenovo 700-15isk
LOL SKL MB
15221-1
448.06R01.0011Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
pls help me Lenovo ideapad 700-15ISK bios repair neededanakart : LOL SKL MB 15221-1448. 06R01.0011
The original bios and ec file is available below. thank you in advanceComment
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
by BOGOSY77Lenovo IdeaPad Slim 3 15ABR8 NM-F031 Rev 1.0
KS486/KS489/KS586/KS681 NM-F031 REV1.0
S/N: PF4YX6CX
Can someone clear or rebuild this one, no display, no fan, only power button on, after 2 hours keyboard back light blink once, that it.
Thank you so much....-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
