GL72 6QF, MS-16J51 me region 0.0.0.0 , powers off
    • 22276
    Re: me region 0.0.0.0 , powers off
    Originally posted by rookieme
    so I replaced the SB as I had one more but it does the very same thing
    I had enough of this one so it's time to let it go unrepaired
    I want to thank everyone of you for your time and effort to help me repair and learn
    Did you run MEInfo.exe -verbose again ? .
    • piernov
      • Jan 2016
      • 4439
      • France
      If you can find it you can try to disconnect the ME Disable signal. On MS-16J51 it means removing R208. And also check voltage on HDA_SDO.
      • rookieme
        • Oct 2014
        • 403
        • Greece
        yes I did, it gave same errors
        • rookieme
          • Oct 2014
          • 403
          • Greece
          I'll let is rest for a while and try what you suggest some days later...
          • Destroyer-Br
            [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
            by Destroyer-Br
            I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
            When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
            If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
            After flashing it, the board does not power on — no signs of life.
            I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
            11-23-2025, 02:48 PM
          • tom3k
            Dell Precision 5540. Need clean ME Region
            by tom3k
            Laptop: Dell Precision 5540
            MB: LA-H331P Rev: 1.0(A00)
            Hi.
            I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
            After extracting my BIOS in FIT the ME Region size is 7565 KB.
            However the ME Region files I fouud online are 11688 KB in size.
            Can someone help me find he correct clean ME Region?
            Thanks!
            Code:
            ║ Family │ CSE ME ║
            06-28-2025, 12:34 PM
          • Adenitz
            Clean ME region - a bit of theory
            by Adenitz
            Hello laptop repair experts,
            can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
            I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
            What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
            Recently, I had a two cases where laptops (one is Lenovo Idepad...
            10-21-2023, 04:44 AM
          • nosaj
            Samsung QN82Q70RA powers on then powers off
            by nosaj
            I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
            So I thought I'd just quit messing around and come to the best site...
            11-07-2025, 04:58 PM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
