Re: ASUS TP412UA BIOS Request / Help with UEFI Tool
Has anyone got a dump of the embedded controller for this model? Just had one come in with a shorted EC, the code isn't in the main BIOS.
thanks work for meLeave a comment:
post it as corrupt as it is and clear pictures with the white or green stickers from the ram memory area..Leave a comment:
A question: some year ago windows update ask me to update the system firmware (bios) i make the update but there's a chance that this procedure save the old bios?Leave a comment:
post the original bios of the laptop..Leave a comment:
@sikocan
sorry if resume this thread a little bit old, so i flash your bios but the same...no video, white led always on, i don't understand if you have changed some components or not, thank youLeave a comment:
Ask for HDD pasword, any ideas?Leave a comment:
Re: Bios for Asus TP412UA
Hi....
Unfortunately I don't have the laptop anymore.......When I will receive an identical laptop I'll let you know.
RgdsLeave a comment:
Re: ASUS TP412UA GPU or CPU not turning ON
Bios flashing fixed. Found one on the net, it worked but 30 sec delay and didn't detect ram. I have fixed those in the attached cleaned me region for others to use.Attached FilesLeave a comment:
Hi peste, this had a different effect and still did not work. What happenes is this:
Turn On
Few seconds, Turn Off.
Turn On,
Turn On. Stay on more than 3 minutes then while staying ON, yellow (amber) light starts flashing non stop. There is no pattern to the Yellow light, just keeps going on and off in a timely fashion, maybe every 1 second.
Same behaviour with SSD inside or out. Same behaviour with or without battery.
I suspect the issue is related to that COIL which has no power. I'm going to remove it and turn it on see if the MOSFET next to it will supply power to 1 leg of coil. If not, I'll go backwards and work on the mosfet/gate situation.
I wonder if there is a way to disable onboard RAM - usually you cam move some resistors around but not sure about this particular model on which and how to.Leave a comment:
try..Attached FilesLeave a comment:
An update if this may help anyone, here is a data log of the state of the BIOS when:
Charger is plugged in, up to 30 seconds of recording, here is the video:
https://youtu.be/4coosr-iv38
When the Power button is pressed. Up 2 minutes of recording, here is the video:
https://youtu.be/iL4g55wsEIALeave a comment:
Hi all and thank you for your help so far. Please I have 2 requests and 2nd is more important then the first.
1. Request for BIOS for ASUS TP412UA Motherboard.
Attached are 3 files related to it:
File 1 is Dump from original BIOS.
File 2 is I've cleaned the Intel ME region from my Dump.
File 4 is Downloaded BIOS from ASUS website to make it easy for you.
2. Request is I've tried to open the File 4 from above in UEFI Tool and attempted to hopefuly export the BIOS region however I can only see "UEFI Image" instead of "Intel Image" as you would with cleaned ME region BIOS or from a Dump. So I've used a Hex Editor to trim down to match both header start and ending to the cleaned and the dump version but I wasn't able to trim it further and wouldn't fit in the BIOS as it was refused by the programmer. I use Raspberry Pie to the programmings using flashrom utility. My request is how can I in the future integrate the BIOS from file ASUS website and into my Dump or generate a BIOS file from ASUS's website.
For this purpose I've attached my trimmed down version of the BIOS file which is File 3, but it's too long. I also make YouTube videos and your help will help me produce the content so others can benefit.
Original fault of the machine for your reference, it turns on and nothing else. It charges battery. No backlight. Caps lock / num lock light when pressed. From watching the fan very closely I can sort of see a loop where it ever so slightly slows down and goes faster again, but faintly, unless I'm imagining.
All voltages are there except Coil Marked on the attached board image which Resistance to ground reading is just above 3 Ohms which I suspect is normal.
Under thermal camera all look good nothing out of ordinary. CPU does start to get warm over time which is normal hence the fan spinning afterwards.
Thank you in advance.Last edited by sikocan; 02-19-2021, 01:13 AM.Leave a comment:
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by ArkzGHey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
What I currently have available:
- Model: FA506NF (2021)
- BIOS chip: GD25LQ16 (16Mbit/2MB)
- Tools: CH341A programmer ready to use
Does anyone have either a clean 2MB .bin dump of this model,...-
by lrouw84Hi there,
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
- Loading...
