Macbook air a1466 emc 3178
  • moderator
    • May 2020
    • 32
    • India
    Hi all , I have A1466 emc 3178 bios chip 2017 model..i wanted clean me..removed the chip/and then lost it ..so i dont have bios file.
    Can anyone please give me a bios file with my serial number and cleanme
    Serial number is FVFW8P6BJ1WK
    • techrecycle
      • Jan 2024
      • 51
      • england
      NEEDS HELP TO UNLOCK PLEASE THANKS
      SR:FVFZ1KE7J1WK
      • peste
        • Dec 2016
        • 12403
        • ROMANIA
        SR:FVFZ1KE7J1WK
        try..
        • techrecycle
          • Jan 2024
          • 51
          • england
          thank sir it works😁😁😁😁😁😁😁🍺🍺
          • Aadi Awan
            • Mar 2019
            • 23
            • paksitan
            Hey Everyone. Need unlock my macbook air 2016
            anyone help plz.
            Modal No . A1466 EMC 3178
            Serial FVFV5875J1WL.
            here is original bios file .... locked file
            • kevingill
              • Jun 2013
              • 152
              • England
              #26
              I've overwrote the section between $SVS markers with FF.
              Should work fine now.
              • trannhan238
                • Jan 2021
                • 18
                • Việt Nam
                #27
                I have a MacBook Air a1466 emc 3178 stuck on the Apple logo (no progress bar). I've tried resetting NVRAM, SMC, and entering recovery mode with no success. I've also attempted BIOS flashing (changed SSN) following this guide: , or keeping the ME region intact and copying a new BIOS region and replacing SSN as instructed. However, after flashing the BIOS, when I power on the device, I only hear the startup sound, the screen backlight turns on, but there's no logo appearing. The funny thing is when i unplugged charger, there's an icon of a plug socket and a battery indicating low battery. Please help.
              • trannhan238
                • Jan 2021
                • 18
                • Việt Nam
                #28
                Serial number: FVFTW82FJ1WL
                • peste
                  • Dec 2016
                  • 12403
                  • ROMANIA
                  #29
                  try..
                  • trannhan238
                    • Jan 2021
                    • 18
                    • Việt Nam
                    #30
                    Originally posted by peste
                    try..
                    Thank you for your help sir. The device is still stuck on the Apple logo without progress bar.
                    • peste
                      • Dec 2016
                      • 12403
                      • ROMANIA
                      #31
                      post the motherboard model...
                      • trannhan238
                        • Jan 2021
                        • 18
                        • Việt Nam
                        #32
                        820-00165-A
                        • peste
                          • Dec 2016
                          • 12403
                          • ROMANIA
                          #33
                          820-00165-A
                          try..
                          • trannhan238
                            • Jan 2021
                            • 18
                            • Việt Nam
                            #34
                            try..
                            no video sir (only startup sound)
                            • trannhan238
                              • Jan 2021
                              • 18
                              • Việt Nam
                              #35
                              First of all, thank mr Peste for your kindly helps!.
                              IT take me alot of timeto read and lean.....I managed to clean ME using version 9.5.3.1526 instead of the original ME version. After flashing, I reset the NVRAM, and it booted from the operating system. However, there is an issue where it doesn't recognize the wifi card and machine shuts down after running for 1 or 2 hours. When I turn it back on, it still doesn't recognize the SSD (question mark and folder). I tried to boot from a installation usb (macOS High Sierra )drive also doesn't detect the internal drive. Even running "diskutil list" command from Terminal doesn't show the SSD. I tried swapping the wifi and SSD from a working machine, but it made no changes , still not recognizing wifi and SSD. When I swapped them back to the other machine, everything worked fine. I suspect it might be a hardware issue or the original ME firmware version 10.0.35.1012 is stuck. To rule out, I cleaned ME with version 10.0.35.1012 from this forum, even fix the BIOS but nothing happend. Please give me some advises. Atually, this is my first time dealing with a MacBook.
                              Thank you in advanced!
                              • 24gsm
                                • Mar 2017
                                • 36
                                • algeria
                                #36
                                hi i need clear this dump MAC a1466 emc 3178 serial FVFWKTAHJ1WK
                                THANKS
                                • peste
                                  • Dec 2016
                                  • 12403
                                  • ROMANIA
                                  #37
                                  THANKS
                                  post the motherboard model, do you want to delete the password, or clear the ME region?
                                  • 24gsm
                                    • Mar 2017
                                    • 36
                                    • algeria
                                    #38
                                    motherboard // MLB 1.8G HY 8G ON // i need delete the password bios thanks
                                    • peste
                                      • Dec 2016
                                      • 12403
                                      • ROMANIA
                                      #39
                                      try..
                                      • fixed4ucy
                                        • Nov 2017
                                        • 11
                                        • cyprus
                                        #40
                                        Hi i need to unlock my bios
                                        can unlock it
                                        model a1466 emc3178
                                        serial fvfxdxcnj1wk
                                        • BMCappelletti
                                          Macbook Air A1466 EMC 3178 missing power and liquid damaged
                                          by BMCappelletti
                                          Hi everyone.
                                          Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
                                          Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
                                          04-15-2024, 01:24 PM
                                        • sherifu
                                          Macbook Air A1466 Emc 3178 No light charger after spilling liquid
                                          by sherifu
                                          Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
                                          03-26-2024, 04:54 PM
                                        • AlexVG
                                          Macbook A1466 EMC 3178 panic CPU caller
                                          by AlexVG
                                          Good night!
                                          I have
                                          Macbook A1466 2017 EMC 3178 A-820-00165-A
                                          It was bad soldering SPI before (I guess somebody have been trying to fix it before)
                                          I have found problem, it runs, but when I am trying to install OS it is interrupted.
                                          I think error is here:
                                          panic CPU caller 0xffffff0014a8c5c0
                                          Would somebody can help me to find what problem is?
                                          Thank you...
                                          12-28-2022, 05:09 PM
                                        • psdavid65
                                          Macbook Air A1466 820-3437-B Booting Problem
                                          by psdavid65
                                          I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                          06-20-2024, 12:27 AM
                                        • stellablu
                                          Macbook Air A1466 EMC 3178 Board 820-00165-A no power
                                          by stellablu
                                          Hi everyone!
                                          I'm working on a Macbook Air A1466 EMC 3178 Board 820-00165-A that doesn't power on. No liquid damage. No fan. I've tried various power adapter, no green nor orange light.
                                          PPBUS_G3H is 8.18V, and from what I've read on other threads it seems that SMC is not communicating to the ISL chip, but I don't know what to do next.
                                          Thanks in advance for help or advices.
                                          01-24-2022, 08:06 AM
