try this
Lenovo 110-15ACL - BIOS
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
by 1g0rHello everyone,
First, the data in brief:
Manufacturer: Lenovo
Model: ThinkPad L15 G3 21C3-0016GE
motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
IC Bios 1: MX77L25650F
IC Bios 2: MX25L25673G
EC Chip: NPCX997KAABX
So far I've been a silent reader, but now I need your help
I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge - Loading...
