Cool very much thank you
Panasonic Toughbook CF-C2 please remove bios password!
I to have a Panasonic Toughbook CF-C2 with bios password what do i use to upload the new firmware posted on here to remove the password pleaseComment
Hello, I have a laptop CF-C2(AECCHCE) S/N 3CTCA17822, I need to downgrade the BIOS version to the initial one, but the Panasonic program does not allow me to do this, reporting error 301. It's all because of the battery, new BIOSes released after 2018 killed the battery. I have rt809h programmer. Thanks.Comment
Hello, following along with this thread I tried using the bios2 on my Panasonic CF-C2, and initially found that I was able to boot it up and navigate to the bios without issue. I then reassembled the laptop and have found that it will now turn on but not display anything on the monitor or on any external monitor. Is there any way you could help please? I've provided a back-up of the original BIOS from before I overwrote it. Any advice would be greatly appreciated
Attached Filesif you find these attachements useful please consider making a small donation to the site
Type the laptop serial number, full name and model, motherboard model, etc.Hello, following along with this thread I tried using the bios2 on my Panasonic CF-C2, and initially found that I was able to boot it up and navigate to the bios without issue. I then reassembled the laptop and have found that it will now turn on but not display anything on the monitor or on any external monitor. Is there any way you could help please? I've provided a back-up of the original BIOS from before I overwrote it. Any advice would be greatly appreciated
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
Hi, the details of the laptop are as follows:
model no. CF-C2AH10HBE
serial no. 3CTCA18577
I'm not sure of the motherboard model at the moment because I've put it all back together, but the bios chip I connected to said 25q128a 13eco 99chn on itComment
Do you know if the information I've provided is enough to go on, or would you like me to strip the laptop down again and try to get the motherboard model for you?
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
Channel: BIOS Requests ONLY!
by razvandcHello, is there anyone who can help me to remove the password from the attached dump file?
The model is Panasonic CF53 DA501FW
I already read the bios chip but I am not sure what to edit precisely in the hex.
Thanks in advance....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
by car_driverHello,
i have a Panasonic Toughbook DF-1D Tablet.
I need the supervisor password for bios. I have only the standard password.
Can anyone tell me the password?
I have read the bios rom and password is encrypted.
Thank you very much....-
- Loading...
