BIOS Lenovo IdeaPad 3 15ARE05 (NM-C861)
  • mantza
    • Sep 2020
    • 36
    • GREECE
    anyone has a bios for this?
  • peste
    • 13599
    • ROMANIA
    Re: BIOS Lenovo IdeaPad 3 15ARE05 (NM-C861)
    post the full name and model of the laptop and the original bios, backup.
    • mantza
      • Sep 2020
      • 36
      • GREECE
      https://www.sendspace.com/file/0jmcca
      • fire1234
        • Dec 2017
        • 77
        • Poland
        bios extracted with exe and dmi data copied
        • mantza
          • Sep 2020
          • 36
          • GREECE
          thank you for the bios, there was a change but still no image, this must have a problem somewhere else, possibly cpu because the laptop was punched, the bios is probably good
          thank you very much though
          • tracker1
            • Jul 2017
            • 118
            • romania
            NM-C861
            Working bios.
            • Sami Wahid
              • Oct 2015
              • 77
              • Morocco
              Re: Lenovo IdeaPad 3 15ARE05
              NM-C861
              Working bios.
              Thank you bro for sharing this dump.
              • jholguin79
                • Jul 2021
                • Dominican Republic
                Lenovo ideapad 5-15ARE05 Laptop - Type 81YQ
                I used a CH341a to restore the BIOS for my Lenovo ideapad 5-15ARE05 after a failed update.
                However I'm unable to restore information on the BIOS such as MTM, Lenovo SN, UUID Number, OS License and OA3 Key ID.
                I would really appreciate your help with restoring this information please.
                Attached are the the original dump backup I extracted before restoring the BIOS (IP5_DUMP_BK.zip) and the new file file used to restore the BIOS (BIOS_e7cn41ww.zip).
                Thank you!
                Regards,
                Jose
                • peste
                  • 13599
                  • ROMANIA
                  Re: Lenovo ideapad 5-15ARE05 Laptop - Type 81YQ
                  Thank you!
                  Regards,
                  Jose
                  try..
                  • jholguin79
                    • Jul 2021
                    It worked and restored all the missing info!
                    Thank you very much @Peste !
                    • FixStation2020
                      • Oct 2020
                      • 8
                      • Philippine
                      Salamat sa pag support
                      • vougheart
                        • Jul 2020
                        • 65
                        • philippines
                        Originally posted by peste
                        try..
                        thank you so much working 100%
                        • errold
                          • Jul 2016
                          • 12
                          • philippines
                          can someone extract exe file latest update lenovo ideapad 3 15are05 bios
                          laptop is working but no bios set up
                          update name: DZCN40WW
                          https://download.lenovo.com/consumer...s/dzcn40ww.exe
                          • peste
                            • 13599
                            • ROMANIA
                            post the original laptop bios
                            • errold
                              • Jul 2016
                              • 12
                              • philippines
                              https://www.mediafire.com/file/zk1mh...-c861.BIN/file
                              • peste
                                • 13599
                                • ROMANIA
                                bios extracted from Lenovo + DMI site update
                                DMI 1000 - 2FFF
                                try..
                                • errold
                                  • Jul 2016
                                  • 12
                                  • philippines
                                  DMI 1000 - 2FFF
                                  try..
                                  tnx brother 100 percent ok
                                  • Dukenukemx
                                    • Nov 2012
                                    • 43
                                    I need some help as I'm trying to fix my IdeaPad 3 15ARE05. It just stopped turning on one day and I thought about a bad bios chip. I desoldered the chip and read it with my CH341A. I found this thread and used the files I found here to flash it onto my Winbond chip. Four tries at flashing the chip resulted in failed verify. Each failed was for a different location in memory. One flash didn't fail but when I read the chip and did a md5sum, they don't match.
                                    To me it seems like a bad flash chip, unless I did something wrong. I'm using Linux Mint and the tool flashrom. It does detect the chip as a W25Q128.W and reading the chip physically does show it to be a 25Q128JWSQ. Only thing is Digikey and pretty much everywhere doesn't show this chip but other similar chips. I did find one Chinese source but I'm not a huge fan of waiting weeks to get my laptop working. Will any W25Q128 chip work or does it need to end with JWSQ?
                                    Also the reason I thought the bios was bad because at first the laptop didn't work but unplugged the CMOS battery would get it working again. I did this multiple times until it just didn't work anymore. Doing a little research I heard this was a common problem for Lenovo. Supply chain issues maybe? Either I'm reading and writing to this chip incorrectly or I found the issue? Here's the terminal results.
                                    Code:
                                    sudo flashrom --programmer ch341a_spi -w BIOS_e7cn41ww.new.bin
                                    flashrom v1.2 on Linux 6.0.8-x64v1-xanmod1 (x86_64)
                                    flashrom is free software, get the source code at https://flashrom.org
                                    Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
                                    Found Winbond flash chip "W25Q128.W" (16384 kB, SPI) on ch341a_spi.
                                    Reading old flash chip contents... done.
                                    Erasing and writing flash chip... Erase/write done.
                                    Verifying flash... FAILED at 0x00b8536b! Expected=0xf6, Found=0xf4, failed byte count from 0x00000000-0x00ffffff: 0x2
                                    Your flash chip is in an unknown state.
                                    Please report this on IRC at chat.freenode.net (channel #flashrom) or
                                    mail flashrom@flashrom.org, thanks!
                                    https://www.digikey.com/en/products/...W25Q128/339728
                                    https://www.ebay.com/itm/275032304442
                                    • peste
                                      • 13599
                                      • ROMANIA
                                      Code:
                                      try one of these programs ... read the chip and post the content here..
                                      https://www.badcaps.net/forum/showpo...6&postcount=10
                                      https://www.badcaps.net/forum/showpo...04&postcount=7
                                      • Dukenukemx
                                        • Nov 2012
                                        • 43
                                        Thanks, just ran NeoProgrammer and it says Verified. It verified twice. I flashed peste's bios that he uploaded. I'll solder the chip onto the board tomorrow and see if the laptop posts.
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
