cannot erase EON S64-100HIP with CH341
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Hello.
    I cannot erase EON S64-100HIP with CH341 on ACER ES1-521.
    everytime i select erase, it show confirm imediatelly wich is bad. I have no problems with other chips. know anyoone some interchange like winbond ic?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: cannot erase EON S64-100HIP with CH341
    i found that somebody want to add this to programmer
    Name="EN25S64",ID="1C3817",Class="W25X10",Category="SERIAL_EPROM",MFG="Eon Silicon",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-099+ADP-081, ADP-081A",Message="Put ADP-099 voltage jumpper on 1V8 position.";
    does it mean i need to use 1.8V adapter or ?
      • 20674
      Use NeoProgrammer software, it supports the chip . https://www.badcaps.net/forum/showpo...04&postcount=7 .It is 1.8V
      If you have a look at this chart on elnec you can work out what the part number means
      https://www.elnec.com/en/device/cFeo...64+%5BSOP8%5D/
      EN XXX XX X XX X X X
      25S = 1.8V Serial Flash with 4kB uniform-sector FLASH
      64 = 64Mbit (8192kx8)
      100 = 100MHz
      H = SOP8, 200mil
      I = Industrial (-40°C to 85°C)
      P = RoHS compliant
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3577
        • slovakia
        detect it, but still erasing took miliseconds and offcourse not erased
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          i took GD25LQ64C from NM-A311 which after been programmed fires on first try
          • kalilinux25
            • Mar 2018
            • 2084
            • ZAMBOANGA SIBUGAY
            100 = 100MHz
            H = SOP8, 200mil
            P = RoHS compliant
            I tried to use this sir but It was taking forever to upload the new bios to the chip.. Do I need to attached a 1.8v adapter?
              • 20674
              The chip is 1.8V so what do you think ?
              • Loli Popu
                DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                by Loli Popu
                Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                12-13-2024, 08:29 AM
              • Sparklingx
                CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
                by Sparklingx
                So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
                So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
                now all...
                08-29-2024, 01:53 PM
              • Peter_1402
                Flashing AM4 BIOS with CH341
                by Peter_1402
                Is it impossible to flash Asus TUF B450M-Plus Gaming BIOS(25LB128D) with CH341? I have done it with H270N BIOS.
                I used NeoProgrammer and selected 25LQ128C IC since 25LB128D is not in the chiplist.dat. I get no response from IC.
                Any expert can help on setting up the import.xml so that I can import 25LB128D into chiplist.dat.
                Thanks in advance.
                07-10-2025, 09:13 AM
              • gsmtim
                Lenovo X1 Yoga Gen5 Accidentally MEC1663 FW Erase Can't Boot
                by gsmtim
                Hi guy's anyOne Have full backup for Lenovo X1 Yoga Gen5 MEC1663 because i accidentally Erase the main FW and EEPRom. i only have backup the Main FW , but i try to Rewrite the 256MB and 288MB but the machine Can't boot, only Charging Indicator and 3blink to power button
                Model # : Lenovo ThinkPad X1 Yoga Gen 5
                Board # : GX4A0/GYG50 NM-C881 REV 1.0
                Serial # : PF-2W2P5H
                Type # :20UC-S1L21H
                06-05-2025, 07:22 AM
              • Haganai.NMWP
                GA-AX370-Gaming 5 BIOS chip MX25U12873F doesn't erase properly
                by Haganai.NMWP
                Hello
                I can't properly erase BIOS chip MX25U12873F.
                I can read it and write it, but before correct write, it have to been erased, but when I click erase program shows success, but when I try do blank verification I have message "chip disconnected".
                I use CH341A programmer with 1.8V adapter and clips.
                When I try read or write it takes 3~5 minutes and "run" LED on programmer is blinking. When I try erase, it takes up to 15 seconds, but "run" LED isn't blinking and after that, chip isn't erased correctly.
                06-01-2022, 06:43 AM
