hi i need bios for my asus e406s
  • YOUN
    • Feb 2015
    • 89
    • Burkina faso
    this is my old dump
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: hi i need bios for my asus e406s
    this is my old dump
    try...
    • maarvinn
      • Mar 2023
      • 4
      • Philippines
      not working for me.
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • TyMercer
        Can I flash a working BIOS from one computer to another of the same make, model, etc?
        by TyMercer
        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
        11-13-2025, 09:39 PM
      • ArkzG
        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
        by ArkzG
        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
        What I currently have available:
        - Model: FA506NF (2021)
        - BIOS chip: GD25LQ16 (16Mbit/2MB)
        - Tools: CH341A programmer ready to use
        Does anyone have either a clean 2MB .bin dump of this model,...
        09-26-2025, 09:34 PM
      • kodox
        Asus ExpertBook B1400CB Bios Dump Needed
        by kodox
        need original bios dump, original bios has flashed by other technician before me.
        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
        unit info:
        Model: Asus ExpertBook B1400CBA-0711A1235U
        S/N: R6NXNZ006657238
        CN: 7F6F
        Mainboard Code: B1500CBA R2.1...
        08-16-2025, 12:20 PM
