DAG71MB16D0 REV. D needed
  • bestdan50
    • Aug 2015
    • 170
    • nigeria
    old bios
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: DAG71MB16D0 REV. D needed
    Try and report.. ME cleared
    Next time post what you need to do or the problem of the bios.. users here are not wizards to guess what the bios problem is
    • ivangserrano
      • Apr 2018
      • 30
      • portugal
      need clean bios please!!
      DAG71MB16D0 REV. D
      no image but with another bios it takes time to give an image.
      attach bios original
      • hoaca388
        Badcaps
        • Jan 2022
        • 12421
        DAG71MB16D0 REV. D
        HP Pavilion - 15-cc504np
        DMI + Window key : 220000h -> 22803Fh
          • 22151
          If you extract the update with 7-zip/winrar youll see some ini files. The cpu is a i7-7500U kabylake U according to the spec page https://support.hp.com/gb-en/document/c05560527 ,so 08361 - 8361_KBL_U is the right bios
          • jackx
            • May 2020
            • 222
            • casa1
            DAG71MB16D0 REV. D hp
            5CD8140CM3 HP Laptop 14-bp0xx
            blinking 5 3 light
            • peste
              • 13793
              • ROMANIA
              blinking 5 3 light
              The bios posted is not from your laptop, you see you mixed them up...
              • tlindi
                Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                by tlindi
                Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                >Read BIOS guides, methods, resources and tools
                Ack
                >Try the method at BIOS guides, methods, resources and tools before requesting help
                Ack
                >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                01-30-2025, 04:26 AM
              • Focus2005
                HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                by Focus2005
                Hello everyone.
                I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                05-01-2025, 05:41 AM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
                by Vesko356
                08-11-2023, 03:27 AM
              • techlab
                HP Elite Dragonfly Bios Crashed - HELP NEEDED
                by techlab
                Hi Guys,
                Looking for some help with an HP Elite Dragonfly.
                The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.
                • The laptop has no power but does take the correct voltage.
                • It shows 5 flashes white/amber, which indicates a BIOS issue.
                • I backed up the original BIOS to extract the feature byte etc.
                • I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
                Just wanted to pick your brains on this — has anyone come across this before or...
                08-29-2025, 05:29 AM
