macbook a1278 clear me
  • piszpunta
    • Jan 2019
    • 249
    • poland
    please clear ME bios
    macbook a1278
    motherboard 820-2530-a
    white screen and full speed fan
    • 21218
    Re: macbook a1278 clear me
    Is it the original bios,whats your serial number .
    • piszpunta
      • Jan 2019
      • 249
      • poland
      yes oryginal
      sn:WQ936AFE66D
      • piernov
        • Jan 2016
        • 4437
        • France
        No ME on Apple Core 2 machines. Try another EFI like https://www.badcaps.net/forum/showpo...99&postcount=2 and edit ssn if confirmed working.
        • Laptop fixer Bulacan
          • Jan 2024
          • 6
          • Philippines
          Hello i need bios bin for macbook pro A1278 820-2530-A thank you very much
          • peste
            peste commented
            Editing a comment
            merged post...
        • peste
          • 12973
          • ROMANIA
          post EMC,post the original bios of the laptop even if it is corrupted,post S/N....
            • Jan 2024
            • 6
            • Philippines
            Here the serial number thank you W8006HAK66D
            • Adogabriel100
              Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
              by Adogabriel100
              Hey! This is a A1278 macbook 2011.
              Problem: Not turning on / No green light
              Im using by3200s charger.
              Voltajes:
              PPBUS_G3H = 12.26v
              SMC_RESET_L = 3.3v
              PP3V42_G3H = 3.42v
              U7000 =
              Pin 1 CHGR_AGATE = 0v
              Pin 2 CHRG_DCIN = 19v
              Pin 3 CHRG_ACIN = 4.6v
              Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
              Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
              Pin 12 PP3V42_G3H = 3.42v
              Pin 13 CHRG_RST_L = 3.3V
              Pin 14 SMC_BC_ACOK = 0.8V
              Pin 19 PP5V1_CHRG_VDD = 5.05V
              Pin 20 PP5V1_CHRG_VDDP = 5.03V...
              04-01-2024, 01:02 PM
            • Rezendes
              Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
              by Rezendes
              Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
              I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
              The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
              05-10-2024, 02:18 PM
            • pcbmaniac
              MacBook A1278 (3115) No PPBUS_G3H Issue
              by pcbmaniac
              Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
              I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
              1. U7000 Measurements:
                • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
              2. Resistors:
                • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
              Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
              • If I also decide to replace the SMC, do I need to order it pre-programmed,
              12-02-2024, 04:12 PM
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
              Apple MacBook A1278 051-7918 820-2327 Schematic
              M97A MLB Rev C...
              11-01-2024, 06:53 AM
