ideapad 3 14iil05 Bios Please
Every donation made will go towards server fees and maintenance costs.Comment
Please repair my BIOS
IdeaPad 3 14iiL05
Model Name - 81WD
SN:PF2JE6GE
MTM:81WD00NCCK
BOARD NM-D031
Notebook works with another BIOS, but i was not able to change SN.
Thanks.Attached FilesComment
you have everything you need at post #7..
https://www.badcaps.net/forum/troubl...os#post1799956
Hello, I would also like to ask for help in recovering a clean BIOS for this same laptop model I have the original file.
IdeaPad 3 14iiL05
Boar model: GS454/GS554/GV450/GV550 REV 1.0 NM-D031
Chip Bios model: 25q128jvsqAttached Files5 PhotosComment
The original file contains the DMI of that machine, so you must backup the original file even if it is corrupted.
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
The picture on the box has more information, I thought it was some other specific information about the BIOS, sorry.
IdeaPad 3 14iiL05
Model Name - 81WD
S/N:PF2ST484
MTM:81WD00U9US
MO: PF9XB1407017Comment
Serial number : PF2ST484Attached Files
Hi guys, someone has for SN: PF2FG96L?
My board is GS454/GS554/GV450/GV550 REV: 1.0 NM-D031 2019-12-06
Please-Comment
the contents of the bios chip...you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
post full name and model,TYPE,etc.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by Yacine007Its a Lenovo ideapad 3-14IIL05 model. Can anyone add all the required DMI info into the working bios file pls. Thanks
Product name : ideapad 3 14IIL05
Model name : 81WD
SN : PF2FFSMM
MTM : 8IWD00QBSP
MO : PF9XB0C26015
MFG DATE : 2020/12/26
FACTORY ID : JVHFC1...-
Channel: BIOS Requests ONLY!
Hello everybody!
i have one ideapad gaming 3
gtx1650
i5
But I don't have the label on the case, so I don't know the model number.
I have the board name GOG10 LA-L161P.
The problem is that it went to another repair shop and they re-recorded the BIOS.
After that, when it turns on, it doesn't recognize the GPU and M2.
It has three BIOSes, all with solder marks.
So I don't know if they re-recorded all three.
The file with all three is attached.
If anyone knows the version and can send me the files, I'd be very grateful for the help....-
Yesterday, 03:10 PM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
- Loading...
