Dell Latitude 6430U Bios dumps (ec+main)
  • pingaroon
    • Nov 2019
    • 121
    • uk
    Hi, does anybody have these?
    The board is LA-8831P. I have successfully flashed a pair of files for E6430 which work, but obviously the model is incorrect and the bios cannot be upgraded in the usual way, so I need the dumps specifically from a 6430U.
    Many thanks
  • Ghamidi
    • Mar 2020
    • 306
    • France
    Re: Dell Latitude 6430U Bios dumps (ec+main)
    Many thanks
    try ..
    • pingaroon
      • Nov 2019
      • 121
      • uk
      Thank you so much. Owe you a beer
      • pingaroon
        • Nov 2019
        • 121
        • uk
        Here's an update on how things went. Your files were version A01 and they allowed the board to boot up fine. Problem is I cannot update the bios. Have tried windows and dos, (it prepares the upgrade, then reboots, but never applies the update). Tried other things like disabling virtualisation, resetting cmos etc, but nothing will allow me to update. I managed to get hold of another 6430u laptop - updated the bios fine on that one, then copied contents of chips over. Now I have A15, but still the same problem - bios will not allow any other version to be flashed. I'm wondering if this is to do the Intel ME data - but I am unable to clear that since even good dumps throw an error using ME Analyzer. If anyone knows how I can fix this, please let me know. Thanks
        • Ghamidi
          • Mar 2020
          • 306
          • France
          here's an update on how things went. Your files were version a01 and they allowed the board to boot up fine. Problem is i cannot update the bios. Have tried windows and dos, (it prepares the upgrade, then reboots, but never applies the update). Tried other things like disabling virtualisation, resetting cmos etc, but nothing will allow me to update. I managed to get hold of another 6430u laptop - updated the bios fine on that one, then copied contents of chips over. Now i have a15, but still the same problem - bios will not allow any other version to be flashed. I'm wondering if this is to do the intel me data - but i am unable to clear that since even good dumps throw an error using me analyzer. If anyone knows how i can fix this, please let me know. Thanks
          try
          • PrimeElect
            • Feb 2017
            • 10
            Great Job Thank you
            • pingaroon
              • Nov 2019
              • 121
              • uk
              to resurrect this thread, I am still looking for a main/ec pair that I can use for this board which will subsequently allow a bios update. The 2 posted by Ghamidi work fine, but cannot be updated via Dell bios update (the machine just reboots). the main bios file gives the output below from MEANalzyer and so I can't attempt to clear the me in the usual way as it can't successfully read in the file...
              ║ U52.BIN.bak (1/1) ║
              ║ Family │ ME ║
              ║ Version │ 8.1.0.1265 ║
              ║ Release │ Production ║
              ║ Type │ Extracted ║
              ║ SKU │ 5MB ║
              ║ TCB Security Version Number │ 1 ║
              ║ Version Control Number │ 2 ║
              ║ Production Ready │ Yes ║
              ║ Date │ 2012-07-05 ║
              ║ Size │ 0x4A4000 ║
              ║ Flash Image Tool │ 8.1.0.1265 ║
              ║ Chipset Support │ CPT/PBG/PPT ║
              ║ Latest │ No ║
              Error: Detected incomplete firmware size 0x800000, expected 0xC00000!
              Warning: Firmware size exceeds Engine/Graphics region, possible data loss!
              Note: Adjusted buffer to Flash Descriptor 0x0 - 0xC00000!
                • 22293
                [QUOTE=pingaroon;1045035]to resurrect this thread, I am still looking for a main/ec pair that I can use for this board which will subsequently allow a bios update. The 2 posted by Ghamidi work fine, but cannot be updated via Dell bios update (the machine just reboots). the main bios file gives the output below from MEANalzyer and so I can't attempt to clear the me in the usual way as it can't successfully read in the file...
                here,try this one.
                • pingaroon
                  • Nov 2019
                  • 121
                  • uk
                  Hi, thanks, yes that works and allows the bios to be updated to later versions of the E6430, but it won't allow 6430U updates, complaining of wrong model. Perhaps there is a way of modifying that dump to change its id to a 6430U, rather than an E6430? Maybe then the bios update could go through?
                  • pingaroon
                    • Nov 2019
                    • 121
                    • uk
                    Hi, update on this - I managed to clear the ME an a good A06 dump from another board. This allows the bios to be upgradeable once installed. bios and ec attached. Note, The E6430 bios is almost the same as the 6430U but does not work 100% the same way (eg problems with how the fan operates), so anyone with a 6430U will need a good pair of 6430U bios files, such as these
                    Finally I can give back on this forum!!
                    • pingaroon
                      • Nov 2019
                      • 121
                      • uk
                      This one has the latest bios A15 and also the latest version of Intel ME. The main dump is truly clean this time (the previous one I posted is not). It can be upgraded but only the main bios and the ec. It will fail when trying to upgrade the Intel ME during the bios update. I made this one by fully updating a healthy board with its native bios/ec still intact, then cleared the ME region on that. There are screenshots included in the attached zip. From what I can glean on the internet, the ME upgrade fails because it thinks it is actually trying to downgrade, so barfs. Anyway, there will probably be no more official Dell updates for the 6430U, so anyone with this board can just use the files in this zip.
                      • nguyendo_yen
                        • Sep 2020
                        • 14
                        • viet nam
                        bios good 100%> Thank you very much
                        • Cesert
                          • Jun 2013
                          • 32
                          • Brazil
                          Work perfectly...Tanks.
                          • zzzlaja
                            • Jan 2019
                            • srbija
                            confirmed good bios...thanks
                            • kubilay
                              • May 2017
                              • 15
                              • türkiye
                              try ..
                              works perfectly
