Hi i need bios dump for terra 1548p bios dump
					Terra 1548P bios dump
 Re: Terra 1548P bios dump
 The problem is no video just black screen.
 My bios dump filesAttached FilesComment
 Please read the "Beginner's guidelines" thread to ID the motherboard part number,as you havn`t posted it.
 https://www.badcaps.net/forum/showthread.php?t=88758
 1.1.3 Motherboard model number
 Clevo: they manufacture laptops for a lot of "small local" brands. There are often 2 model numbers on the board, like "6-71-W25S0-D02" and "W251ESMB-D0"Comment
 w650sjmb-0dComment
 I try with this one working
 but wifi not working, Can be fixedAttached FilesComment
			by AhariHi all,
 I...-
			by mkdjDear all,
 I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
 Suspected Cause:
 Troubleshooting Attempts:
			Hello engineers 😀,
 I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
 🔧 Device Info:
 - Model: HP 15-da2007ne
 - Product Number: 8XF55EA#ABV
 - Serial Number: CND0338P0D
 - CPU: Intel Celeron N4000
 - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
 💀 Problem:😅
 - Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
 S/N : 5RNK9FFT70...-
- Loading...
