Bios Chip 25B64CSIG and EZP2019+ help request
  • raselm
    • Aug 2020
    • 3
    • Bangladesh
    I am new here.
    Need your help with similar situation.
    I am using EZP2019+ programmer.
    The bios chip is 25B64CSIG, assume the manufacturer is Gigadevice since the "CSIG" type keywords come after their produces.
    However in the EZP2019+ this is not listed under their brand. How can I add the missing chip in it's library. could someone please help.
    Or the compatible chip ID from the below list.
    https://www.hklrf.com/24download/img/EZP2019-List.txt
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Bios Chip 25B64CSIG and EZP2019+ help request
    select GD25Q64 and its likely to work. If your chip is 1.8V, then select GD25Q64(L)
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      I have the same BIOS chip , i used Neo programmer suggested by a senior member
      https://www.badcaps.net/forum/showth...Programmerchip.
      Neo Programmer will easily choose your correct and single IC marking.Neo Programmer has 25B64CS1G IC in it's list.
      No need to choose another just try Neo Programmer and it will work
      It is not helpfull to use clip adapter instead remove chip from motherboard and use SOC adapter to reflash the chip
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Hi ,
        @raselm 25B64CS1G IC ,3.3 volts
        Please do share which Laptop model number and brand you are using, if your
        bios dump can save my laptop i will check your Bios file.
        Post your Bios dump
        • Wachenaggo
          • Jul 2018
          • 66
          • Philippines
          Originally posted by raselm
          I am new here.
          did you resolve this problem???
          • robertbayoe
            • Feb 2022
            • INDONESIA
            EZP2019+ can detect 25B64CSIG
            • tomstech
              • Mar 2024
              • lincolnshire
              Hello, does anyone have the bin files for the 25B64CSIG? thanks
                SMDFlea commented
                Editing a comment
                Off-topic .
            • jack bah
              • Mar 2023
              • 10
              • Sénégal
              I am new here.
              Hello, how can you tell if a BIOS chip is powered by 3V or 1.8V ?
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • inck243
                Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                by inck243
                Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                The BIOS...
                07-25-2024, 09:17 AM
              • Azurain
                Elitebook 840 G5 Bios Chip Soldering Question
                by Azurain
                I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                04-14-2023, 06:58 PM
