Hp Pavilion DV6700 - BIOS
  • vinkos
    • Jul 2013
    • 51
    • Netherlands
    I am looking for bios location on DV6700 (AMD) or schematic of this motherboard!
    Thanks in advance.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: Hp Pavilion DV6700
    Thanks in advance.
    here what you are looking for 100% working
    • vinkos
      • Jul 2013
      • 51
      • Netherlands
      Thank you very much, but i do need to locate bios chip on the motherboard!
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        here
        • vinkos
          • Jul 2013
          • 51
          • Netherlands
          Thanks Pragmatico!
          I successfully change it !
          • Pragmatiko
            • Jul 2013
            • 468
            • IT
            Why replaced? Just need reprogram.
            • vinkos
              • Jul 2013
              • 51
              • Netherlands
              Yes,i did try with EZP 2010 progg. but it did not recognize chip .
              Well i am not expert for programing also !
              Then i take it from faulty dv9000 motherboard (same bios) and
              put it on!
              Anyway about Spi programmer for bios ! Witch is the best one.
              • pravin6p
                • Mar 2014
                • 75
                • india
                Da0at3mb8f0 rev : F bios
                • mehdisfr
                  • Jan 2017
                  • 13
                  • tunisia
                  Download and reset bios for HP Pavilion DV6000 DA0AT3MB8F0 dump
                  https://www.youtube.com/watch?v=S8DRJz-a5Fo
                  • leetech
                    • Mar 2018
                    • 6
                    • kenya
                    Re: Hp Pavilion DV6700 - BIOS
                    • peste
                      • Dec 2016
                      • 13451
                      • ROMANIA
                      always when you ask for a bios post the original bios of the laptop, even if it is corrupted.. the name and the model..
                      • Developer AKRAM
                        • Feb 2025
                        • 12
                        • Algeria
                        HI
                        i need bios file for HP Pavilion DV6700
                        board model : DA0AT3MB8F0 REV F
                        dump :
                      • Developer AKRAM
                        • Feb 2025
                        • 12
                        • Algeria
                        serial number : CNF8046K5S
                        • peste
                          • Dec 2016
                          • 13451
                          • ROMANIA
                          try..
                          • Developer AKRAM
                            • Feb 2025
                            • 12
                            • Algeria
                            Originally posted by peste
                            try..
                            i will try it later and respond
                            • Developer AKRAM
                              • Feb 2025
                              • 12
                              • Algeria
                              didn't work
                              • Bloodhoundje
                                HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                by Bloodhoundje
                                I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                I have desoldered the bios chip (GigaDevice...
                                03-16-2024, 03:12 PM
                              • hotcrossedbuns999
                                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                by hotcrossedbuns999
                                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                3. I could only locate two chips that look like bios chips. Could someone verify this
                                01-03-2025, 12:32 PM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • sssssssssssssss
                                Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                                by sssssssssssssss
                                I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                                Symptoms:
                                • Laptop powers on but no display at all (completely black screen)
                                • Caps Lock blinks twice with a pause, then repeats continuously
                                • F12 LED stays on permanently
                                • No POST, no boot sequence, nothing on screen
                                Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                                What I've tried:
                                • Hardware reset (battery removal, power
                                09-04-2025, 06:45 AM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
