haai..anyone have apple 820-2023-a bios file..pls?
by miccodanDevice: Laptop
Brand: Dell
Model: Inspiron 7573 2-in-1
Service Tag:1G8B6P2
Board number: kylo ren 15 16841-1 H7TJX
Symptoms: With original bios the laptop will not post, keyboard and power light flash on/off upon pressing power button and no fans spin. Attempted to use bios found on here and with other bios the laptop powers on and fans run at full speed and stays running but will not post.
original bios is attached. Many thanks in advance!-
Channel: BIOS Requests ONLY!
by JoWedHello Community,
I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...-
by thxd43Hello, first of all, excuse me, I am using the translator, English is not my native language.
I have a Lenovo ideapad 330S - 14IKB laptop.
The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a... -
by legendkrayHi,
I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...-
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
- Loading...
