Da0y0dmbaf0 rev:f
  • alihomee
    • Dec 2012
    • 1599
    • malaysia
    Da0y0dmbaf0 rev:f
    with ori file boot loop ....anyone can modify the file will be appriciated
  • Bonzas
    • 474
    • Indonesia
    Re: Da0y0dmbaf0 rev:f
    Try this, extracted from hp
    • alihomee
      • Dec 2012
      • 1599
      • malaysia
      same boot loop with this file .....all supplies on mobo turning on but after every 5 seconds it restarts
      • Bonzas
        • 474
        • Indonesia
        Did you check where drop voltage while turning on ?
        check U22
        • dennis akumu
          • Mar 2018
          • 113
          • kenya
          Hi,anybody with this file clean me please assist.
          Brnd.spectre pro x360 g1.
          Board no.da0y0dmbaf0 rev f.
          Product id;n6k95uc#acj.
          Attached is the original file.plese help with a claen file.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            7. Extracting BIOS/EC firmware from update packages
            https://www.badcaps.net/forum/showpo...45&postcount=7
            [Guide] How to extract ready for programming dump from HP update executable file
            https://www.badcaps.net/forum/showthread.php?p=1259537
            Extract your bios from from the HP update executable, find the BID number in your backup and use the offsets below to transfer DMI + Windows key from your dump to the new one.
            DMI: 6CCF00 - 6CD0FF
            Windows Key: 6EE000 - 6EE03F
            Become a Badcaps supporter
            Thanks to all supporters.​
            • jithinkn
              • Jul 2018
              • 40
              • UAE
              Bios recovery fail , plz rebuild
              SN- 5CD5243H1H
              Model; 13-4007na
              MB .DA0Y0DMBAF0 . REV: F
                • 22279
                SN- 5CD5243H1H
                Model; 13-4007na
                Read the post above,you can find and extract the right bios. If you can`t add the DMI yourself let us know and someone will help
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • to5it0
                  by to5it0
                  10-24-2025, 01:35 AM
                • Daniel Larsson
                  Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                  by Daniel Larsson
                  My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                  I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                  During these seconds the function button is not working...
                  08-13-2025, 10:29 AM
                • Forest79
                  by Forest79
                  07-23-2023, 07:39 AM
                • Takeatry
                  Yet another Samsung QLED Boot Loop
                  by Takeatry
                  Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                  10-04-2024, 02:57 PM
