SATTELITE P845t -S4310 TOSHIBA BIN FILE
  • daryl_rasta
    • Jul 2019
    • 14
    • philippines
    Badly need bin file for this model
    the problem of laptop is bios password only
    thanks
  • peste
    • 13920
    • ROMANIA
    Re: SATTELITE P845t -S4310 TOSHIBA BIN FILE
    thanks
    post the original bios ..
    • kulas13
      • Aug 2020
      • quezon city
      pls help me i need this bin file
      • peste
        • 13920
        • ROMANIA
        read post # 2
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • HOHA
          BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
          by HOHA
          Hi can you help me
          I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
          IP3_TN16S_MB_V30_20210901A
          This is the old BIOS file, it is corrupted​...
          10-20-2024, 08:22 AM
