looking for working bios file ...ori is attached and with this file no display on screen only caps lock blink.....mobo code is EPK50 LA-G07AP Rev:1.0
hp 15-da0005tx
Re: hp 15-da0005tx
you BID084A6
extract official site hp:Attached Filesif you find these attachements useful please consider making a small donation to the site
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by joshAUHi all.
I'm looking for a BIOS file for an Asus N550JK.
I have a Asus R552J, which I believe is identical to the Asus N550JK.
I downloaded the latest BIOS (210) for the R552.
It is named N550JKAS.210.
The BIOS file is however only 6mb in size.
I've read the chip with a CH341A programmer and verified the file.
That file is actually 8mb in size.
I'm wanting to remove the BIOS password from this unit.
It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...-
by wishes2022Hi Guys ,
How to extract attached BIOS file. please help。
Thanks in advance ! from china-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
