samsung np915s3g-k01ph need bios
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need a working bios on this model samsung np915sg BA41-02277A REV:1.0, attached is the original dump, the problem it turns on fan spin but no display, ram is onboard
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: samsung np915s3g-k01ph need bios
    anyone can help please
      • 21467
      bios,P11RBV.
      • warsztat
        • Feb 2017
        • 190
        • Polska
        Thank you SMDFlea you bios work good.
        • lordraven27
          • Jun 2018
          • 6
          • philippines
          • Sergioz
            • Apr 2016
            • 12
            • New Zealand
            Legend!
            • oxidaoza
              • Feb 2022
              • Argentina
              Thanks a lot! It also worked on Samsung NP915S3G-K03AR. Greetings from Argentina!
              • salawayon
                • Nov 2012
                • 577
                • philippines
                Re: Bios dump samsung np905s3g
                got a NP915S3G model with no display issue. tried the NP905S3G bios but still the same. backup attached..
                board info:
                PETRA-13 (BA41-02277A) REV 1
                • kubilay
                  • May 2017
                  • 15
                  • türkiye
                  bios,P11RBV.
                  works great
                  • Kjell
                    Samsung Series 9 - BIOS issue
                    by Kjell
                    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                    08-01-2025, 09:15 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                    by Vesko356
                    08-11-2023, 03:27 AM
                    09-07-2024, 05:50 AM
