PLEASE Hp 14-cf1061st CLEAN ME BIOS
  • reflexible
    • Apr 2016
    • 47
    • ukraine
    Good evening, please does anyone have a bios dump Hp 14-cf1061st HEDWIG2 - 6050A3155301 - MB - A01 working and region clean?
    Thank you very much for the help.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: PLEASE Hp 14-cf1061st CLEAN ME BIOS
    bios extracted from the HP site update, the laptop has four versions of the bios, yours is 0852C
    DMI + KYIWIN 310000-31103F
    • reflexible
      • Apr 2016
      • 47
      • ukraine
      Tried several times without success with )))
      • reflexible
        • Apr 2016
        • 47
        • ukraine
        Motherboard has start but no display. Any ideas?
        • reflexible
          • Apr 2016
          • 47
          • ukraine
          my bios dump is corrupted.
          I can't do anything with it.
            • 22285
            Look around the board for another bios chip, i think it has two.One is for surestart recovery.Post it if there is one (backup) and some pictures with both chip locations.
            • reflexible
              • Apr 2016
              • 47
              • ukraine
              is only 25Q128 bios chip
                • 22285
                Ok, try this one. There are two 0852C bios in the extracted upate,not sure why yet but both have differences.
                • reflexible
                  • Apr 2016
                  • 47
                  • ukraine
                  works 100%!!! thanks!!!!!
                  • reflexible
                    • Apr 2016
                    • 47
                    • ukraine
                    the problem with laptop is that it goes to sleep mode and won't turn on during some time. When i trying to turn it on, it turns on after several minutes with 0,30 GHZ frequency and normalized after 40 min. I was trying to gat bios ME region but i got error -the me/txe region is corrupted or missing. Do you know what the problem is?
                      • 22285
                      The bios you posted has BID0852C so we can only assume that the bios was the original one. I`ve now found your bios on another site (paid) for the exact model number 14-cf1061st and the BID is different, its 08498 .Is the laptop serial number 5CG9404YVW ? ,If it is then the DMI info can be added to the 08498 posted by @peste, thats if the DMI info is stored at the same address,and if it isn`t use HP bios config utility/wndmifit to add it.
                      • reflexible
                        • Apr 2016
                        • 47
                        • ukraine
                        Tried several times without success with ))) 25Q128 bios chip
                        this is my serial number 5CG9404YVW!
                        • teknisioon
                          • Jun 2021
                          • 5
                          • thailand
                          Works For Me. Thanks A lot
                          • PURNAMA
                            • May 2020
                            • 64
                            • jakarta
                            Thank's working
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • haitham sharabati
                              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                              by haitham sharabati
                              Hello engineers 😀,
                              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                              🔧 Device Info:
                              - Model: HP 15-da2007ne
                              - Product Number: 8XF55EA#ABV
                              - Serial Number: CND0338P0D
                              - CPU: Intel Celeron N4000
                              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                              💀 Problem:😅
                              - Device shows “Administrator Password”...
                              08-07-2025, 04:54 AM
                            • Citymin
                              by Citymin
                              S/N : 5RNK9FFT70...
                              08-05-2025, 05:12 AM
                            • loopster
                              Need help cleaning ME region on Zbook 17 G1 bios dump
                              by loopster
                              Hello guys,
                              could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                              Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                              I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                              Error 10: Failed to open with processed commands.
                              Unable to open file: C:\Users\Elitebook...
                              06-16-2024, 09:57 AM
