Compaq Presario CQ71 BIOS
  • Edson ja
    • Sep 2020
    • Moçambique
    Can someone help me.
    I need the HP Compaq BIOS file
    Product: Presario CQ71
    Model: CQ71-306EI
    • 22276
    Re: Compaq Presario CQ71 BIOS
    Model: CQ71-306EI
    Post your bios backup
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
