help me CLEVO w761c dump
  • didouche1200
    • Oct 2016
    • 354
    • 82679911441
    6-71-m77c0-d14 gp bios dump
    thinks...
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • grimacelord
    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
    by grimacelord
    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
    Motherboard model number: DA0PAMB46A1 REV: A
    Secondary motherboard model number: 0PAB
    SKU: 685K4UA
    Serial number is: 5CD3223BJP
    Recently reflashed this laptop with latest BIOS and once...
    05-07-2024, 08:06 AM
  • DynaxSC
    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
    by DynaxSC
    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
    11-06-2022, 05:22 PM
  • TacticalFahrrad
    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
    by TacticalFahrrad
    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
    06-30-2025, 04:09 AM
