HP EliteBook 820 G1 Bios
  • bilen
    • Aug 2014
    • 632
    • istanbul
    Re: Hp 820 g1
    Originally posted by peste
    try..
    the result is the same.
    Could the problem be ec?
    • peste
      • Dec 2016
      • 12734
      • ROMANIA
      Re: Hp 820 g1
      I'm trying this too ..
      • bilen
        • Aug 2014
        • 632
        • istanbul
        Re: Hp 820 g1
        no screen.
        can you fix ec?
        • vtfe
          • Sep 2017
          • 35
          • france
          Need Main + EC BIOS for HP 820 G1 (6050A2630701-MB-A01)
          I need to flash main and ec bios for HP 820 G1 (for chips U365 and U366). Please provide both BIOS files.
          Thank you
          Symptom:
          Laptop does not boot. When battery or power is plugged in:
          - Fan spins fast for a few seconds then stops
          - Power button led is steady white
          - Caps lock led is steady white
          - Front white led is steady and amber led blinks repeatedly
          - CPU heatsink is VERY hot to the touch
          - Blank screen (no backlight, no nothing)
          • peste
            • Dec 2016
            • 12734
            • ROMANIA
            Re: Need Main + EC BIOS for HP 820 G1 (6050A2630701-MB-A01)
            Thank you
            Symptom:
            post the original bios
            • vtfe
              • Sep 2017
              • 35
              • france
              #26
              Here are the BIOSes I dumped from the PC:
              - Main BIOS (16MB)
              - EC BIOS (2MB)
              Please find them attached.
              • peste
                • Dec 2016
                • 12734
                • ROMANIA
                #27
                - Main BIOS (16MB)
                - EC BIOS (2MB)
                try..
                • vtfe
                  • Sep 2017
                  • 35
                  • france
                  #28
                  Thanks!
                  I will let you know
                  • vtfe
                    • Sep 2017
                    • 35
                    • france
                    #29
                    Thanks again for your help, but it didn't work. There must be a short on the motherboard. I give up on this board.
                    • patrikk91
                      • Jun 2018
                      • 3
                      • NyĂ­regyháza
                      #30
                      Re: HO EliteBook 820 G1
                      Main BIOS is U365 EC U366
                      • O.Szilard
                        • May 2019
                        • 161
                        • hungary
                        #31
                        Re: HP-Compaq - Elitebook 820 g1 BIOS error
                        Hello! Help start the HP 820G1. After switching on, Capslock 3 flashes, the fan at high speed. Bios error?
                        • peste
                          • Dec 2016
                          • 12734
                          • ROMANIA
                          #32
                          Originally posted by O.Szilárd
                          Hello! Segítse a HP 820G1 indítását. Bekapcsolás után a Capslock 3 villog, a ventilátor nagy sebességgel. Bios hiba?
                          try..
                          • O.Szilard
                            • May 2019
                            • 161
                            • hungary
                            #33
                            Re: HP-Compaq - Elitebook 820 BIOS DUMP
                            thanks for the help but it didn't get good. the motherboard is dead likely
                              • 20793
                              Did you try different RAM ? .How can you say its dead without further testing
                              • O.Szilard
                                • May 2019
                                • 161
                                • hungary
                                #35
                                yes, i tried more RAM. I did all the tests, voltage is fine everywhere. I'm out of my mind. Processor BGA error? With a microscope motherboard I looked carefully, everything was fine. 2 RAM slots are also good. But it's not working
                                • O.Szilard
                                  • May 2019
                                  • 161
                                  • hungary
                                  #36
                                  main : SWBACK15-6050A2630701-MB-A01 (HSTNN-I13C)
                                  • peste
                                    • Dec 2016
                                    • 12734
                                    • ROMANIA
                                    #37
                                    try this..
                                    • O.Szilard
                                      • May 2019
                                      • 161
                                      • hungary
                                      #38
                                      thanks for the help but same as before, 3 flashes capslock + numlock and doesn't work
                                      • O.Szilard
                                        • May 2019
                                        • 161
                                        • hungary
                                        #39
                                        Hello! I closely observed laptop malfunction. after switching on 3 flashes capslock + numlock five times in a row. so 3-3-3-3-3 and no more. cpu problem? Do you have an idea?
                                        • Genova
                                          • Jan 2020
                                          • 116
                                          • FRANCE
                                          #40
                                          Hp 820 g1
                                          I'm trying to recover my bios file with CH341A and Asprogrammer 1.4.1 on a 820 g1.
                                          I connect the clip, i push "Read Id with ?" chip is detected i do it again chip also detected and direct after the yellow orange led lights up and the bios is no longer detected.
                                          All battery are disconnected and it doesn't matter if I connect the charger or not it's the same thing.
                                          Any help or idea on this ?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • moshu
                                            HP EliteBook 755 G4 bios password locked
                                            by moshu
                                            Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                            I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                            Can you please help to remove the password?
                                            after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                            HP EliteBook 755 G4
                                            ProdID: W5Q98AV
                                            SN: 5CG7524BY4...
                                            02-01-2025, 06:59 AM
                                          • iZakre
                                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                            by iZakre
                                            Hello everybody!
                                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                            The thing is that I had installed TeamViewer and could log into the computer...
                                            02-19-2023, 02:27 PM
