Help me to unlock dell 5580
  • carimbenzema
    • Jul 2024
    • 7
    • Cameroon
    #121
    Originally posted by carimbenzema
    Hi guys how are you! Can someone help me with the password bios unlock for DELL Latitude 5580 #9216WD2-E7A8? Service TAG(SN)FBYV1N2
    i do not have his programmer, is possible to generate the master password?
      • 22293
      It`s possible yes, read the dell password post -> https://www.badcaps.net/forum/troubl...23#post1622423
      • omran1@!
        • Dec 2020
        • 22
        • syria
        #123
        hello can any one help me
        my laptop dell E5580
        and the GPU don't show in device manager
        and all voltage is ok
        sn : Jkdpl2
        la-e152p rev 1.0
        • alito666
          • Jul 2025
          • 32
          • mexico
          #124
          hi members i have this 2 laptop dell 5580 password locked i try generate the code but not unlock,
          can generate master code for this st please
          JCDR1G2-6FF1
          85ZW1G2-6FF1
          • LBTT1121
            • Nov 2024
            • 1239
            • Việt Nam
            #125
            JCDR1G2-6FF1
            85ZW1G2-6FF1
            use https://bios-pw.org/
            • alito666
              • Jul 2025
              • 32
              • mexico
              #126
              Originally posted by LBTT1121
              yes i use Ctrl+enter i try with tip bf97 also my keyboard is qwerty also try with usb keyboard before i use that site for generate master code and works for other suffix but with this 6ff1 i have problems
              • LBTT1121
                • Nov 2024
                • 1239
                • Việt Nam
                #127
                Try : Ctrl Left +enter +enter
                • calade
                  • Feb 2016
                  • France
                  #128
                  Could you please help me to remove BIOS password on DELL E5580 with System Number : FVC4HM2-E7A8
                  Thank you !
                  • m1ch43lzm
                    • Mar 2019
                    • 1135
                    • Peru
                    #129
                    3.4. Dell
                    Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                    See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                    Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                    Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                    Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                    Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                    Note: There is no publicly available 8FC8 generator available at the moment.
                    The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                    From bios-pw.org website
                    FVC4HM2-E7A8
                    Code:
                    5G51Q3D6ZXQz[Z2q
                    xRye1byZPU[knzrr
                    Use a QWERTY USB keyboard if possible, on FR AZERTY you have to replace Q<>A, W<>Z M is to the right of N, [ is to the right of P
                    For the numbers don't press Shift
                    Try both
                    Code:
                    5G51A3D6WXAw^W2a
                    xRye1byWPU^knwrr
                    Passwords are case sensitive, UPPERCASE vs lowercase
                    At the end press LeftCtrl-Enter​
                    • wolfdopd
                      • Sep 2025
                      • germany
                      #130
                      Hi i have a Dell 5580 9R9XMH2-6FF1
                      tried c4wZmWz1VB84UzRf with CTRL+Enter and its not working ?
                      Any help on this please
                      • ERRA
                        • Sep 2025
                        • 45
                        • Morocco
                        #131
                        Flash a new clean bios bro, then set the service tag in bios settings
                        • m1ch43lzm
                          • Mar 2019
                          • 1135
                          • Peru
                          #132
                          Use QWERTY keyboard, if you have German QWERTZ keyboard swap all "z" <> " "y" on the given password
                          From Dell support website
                          583-BDOP : Intern Deutsch QWERTZ Tastatur mit Hintergrundbeleuchtung
                          US English QWERTY keyboard for reference, type the password as if it were on QWERTY keyboard
                          Try this first (on QWERTZ) 9R9XMH2-6FF1
                          Code:
                          c4wYmWy1VB84UyRf
                          Also try with different suffix
                          Try 9R9XMH2-1F5A (same on both layouts)
                          Code:
                          p09SNn9QuI4i0u29
                          Try BF97 (QWERTY)
                          Code:
                          rRzzJDzILBGGzyaN
                          Converted to QWERTZ
                          Code:
                          rRyyJDyILBGGyzaN
                          • florenz
                            • Apr 2018
                            • 50
                            • Cameroon
                            #133
                            Hello Guys please i need help , i would like to remove computrace on a 5580 Dell Latitude.
                            ST: DBZPZM2
                            mother board model : CDM80 LA-E092P
                            IN attachments the BIOS + EC .
                            thx in Advance
                              • 22293
                              ST: DBZPZM2
                              thx in Advance
                              try this https://www.badcaps.net/forum/troubl...79#post3633379
                              • florenz
                                • Apr 2018
                                • 50
                                • Cameroon
                                #135
                                Originally posted by SMDFlea
                                thx for the feedback i tried and i had an error issues , kindly see the screenshot in attcachments.
                                thx
                                • ERRA
                                  • Sep 2025
                                  • 45
                                  • Morocco
                                  #136
                                  ST: DBZPZM2
                                  thx in Advance
                                  Corrupted files!!
                                  • florenz
                                    • Apr 2018
                                    • 50
                                    • Cameroon
                                    #137
                                    Originally posted by ERRA
                                    Corrupted files!!
                                    so?
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 1135
                                      • Peru
                                      #138
                                      florenz Read BIOS chip again W25Q128
                                      • florenz
                                        • Apr 2018
                                        • 50
                                        • Cameroon
                                        #139
                                        that'sthxu
                                        • ERRA
                                          • Sep 2025
                                          • 45
                                          • Morocco
                                          #140
                                          that'sthxu
                                          try this password:
                                          BfDroUbCc3ZVxVre (use qwerty layout)!
                                          * for some Dell codes press Ctrl-Enter, not Enter, when entering code into the BIOS (https://bios-pw.org/)
                                          if not working flash this file:
                                            DELL Inspiron 5580 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 5580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5580 boardview and 5580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5580...
                                            09-06-2024, 09:45 AM
                                            09-06-2024, 08:20 AM
                                            DELL Latitude 5580 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5580 boardview and 5580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5580...
                                            09-06-2024, 08:01 AM
