Lenovo v110-15ikb
  • baki60
    • May 2020
    • 78
    • Türkiye
    Lenovo v110-15ikb
    there is no image to see
    I added bios
    Can you be a new bios assistant, masters
    Thank you
  • peste
    • 12582
    • ROMANIA
    Re: Lenovo v110-15ikb
    I added bios
    Thank you
    the bios is empty..check and post again
    • baki60
      • May 2020
      • 78
      • Türkiye
      gives a reading error
      ye can find bios
      thank you
        • 20633
        ye can find bios
        thank you
        What model is your bios programmer,have you desoldered the bios or are you using a clip ?
        • baki60
          • May 2020
          • 78
          • Türkiye
          ezp2010
          master
            • 20633
            have you desoldered the bios or are you using a sop8 clip ?
            • baki60
              • May 2020
              • 78
              • Türkiye
              no problem with soldering
              ezp2010
              • baki60
                • May 2020
                • 78
                • Türkiye
                can you add a new bios master
                • baki60
                  • May 2020
                  • 78
                  • Türkiye
                  please help
                  i need bios
                  • peste
                    • 12582
                    • ROMANIA
                    please help
                    i need bios
                    post the original bios so we can help you ..
                    • baki60
                      • May 2020
                      • 78
                      • Türkiye
                      This is the backup I can get
                      • peste
                        • 12582
                        • ROMANIA
                        it is also empty ... before posting it here check it with the HxD program if it is empty or it is ok..download the program from the net, install the program and check the bios, find on the net video how to use HxD, then post the correct bios ..do not use the clip because it gives errors..remove the chip from the motherboard read it, make a copy check it with HxD prog and if it is ok post it here..find on the net video how to use your programmer ..
                        • baki60
                          • May 2020
                          • 78
                          • Türkiye
                          I removed the bioas integrated damaged mainboard, I have a new integrated plug, but I have no bios software
                          • peste
                            • 12582
                            • ROMANIA
                            give the model of the motherboard
                            • baki60
                              • May 2020
                              • 78
                              • Türkiye
                              Can you check if this is suitable bios masters
                              • lrservicios
                                • May 2016
                                • 127
                                • españa
                                Working Bios For Lenovo V110-15IKB
                                Motherboard : LV115KB MB 15277-2N 448.08B01.002N
                                • Wahaz
                                  by Wahaz
                                  10-30-2023, 08:42 PM
                                • grimacelord
                                  by grimacelord
                                  Hello there.
                                  History:
                                  03-15-2023, 03:29 PM
                                • jendkkd jeje
                                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                  by jendkkd jeje
                                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                  10-11-2024, 03:12 PM
                                • mximiliandz
                                  help bios lenovo ideapad s145-14iil type 81w6
                                  by mximiliandz
                                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                  06-20-2025, 06:50 AM
                                • 1g0r
                                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                  by 1g0r
                                  First, the data in brief:
                                  Manufacturer: Lenovo
                                  Model: ThinkPad L15 G3 21C3-0016GE
                                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                  IC Bios 1: MX77L25650F
                                  IC Bios 2​: MX25L25673G
                                  EC Chip: NPCX997KAABX
                                  So far I've been a silent reader, but now I need your help
                                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                  01-18-2025, 02:39 AM
