HPDMI unable to add SN after flashing BIOS
  • pappyN4
    • Aug 2020
    • 5
    Hi all
    I have an old HP Mini 1000 series netbook that I occasionally still use. I got a newer wifi card upgrade from an old junk laptop that was being tossed. I had to update the BIOS with a modded one to bypass a wifi whitelist check.
    Windows itself works ok, but when I try to add the model/SN/etc... with HPBQ193 (NbDmiFit_1.14B.zip USB boot with DOS) it does not save it to the EEPROM. The ESCD.dat file is created, says its saved, but as soon as you exit the app and start hpbq again all the info is gone.
    I dont know the policy of linking to other sites, but the bios-mod file I flashed is:
    361A0F15_NWL_ByCamiloml
    Any ideas?
    • 20942
    Re: HPDMI unable to add SN after flashing BIOS
    Post your original bios .
    • pappyN4
      • Aug 2020
      • 5
      Here's backup of original.
      It's older 361A0 F12 version so missing some bug fixes compared to F15 and will not boot with 104 error due to new wifi card.
      model:HP Mini 1137NR
      SKU:NM119UA#ABA
      CTO:ABA
      serial:CNU.....FX
      • pappyN4
        • Aug 2020
        • 5
        Comparing the two BIOSes in hexplorer. In the original, the only place I see the serial number/SKU mentioned is in a little island of text starting at position ec000h in a huge sea of "FF". While ec000h in the NWL modded bios is all FF at the position. Would copying that block of text over to that position work?
        • pappyN4
          • Aug 2020
          • 5
          So to answer my own question in case it helps someone else. Yes
          Copied over block from ec000 and ec800 and flashing it restored back logo and hardware info.
          • helpmepleasethanks
            Thinkpad T440P bios repair after WIFI whitelist mod
            by helpmepleasethanks
            As per the the rules, here are the specifications of my laptop :
            • Make and model number : Thinkpad T440P
            • Serial number (S/N) : PB-03A7V7
            • Model type - Model (MTM) : 20AW-S2N800
            • Bios version : 2.50 (not 100% sure, that's what I remember)
            Here is the problem, and the events leading to it :
            1. Upgrade screen, keyboard, trackpad, RAM and CPU
            2. Reboot and use the laptop for a bit : everything is working fine
            3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
            4. Boot up the device : bios warning, as expected
            5. Shutdown the device again (no power)
            6. Connect the 8-pin clip of a CH341a
            01-09-2025, 12:09 PM
          • Timeeez
            X270 - Bios flashing help
            by Timeeez
            I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
            Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
            11-30-2022, 05:17 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • Flyview
            Flashing ASUS UX51VZ with correct bios
            by Flyview
            Hi!
            Happy to be part of this forum for my first post!
            Short story:
            I believe my dad's UX51VZ has an incorrect bios (v207) for a UX51VZH flashed onto it. I'm not quite sure what the differences are between UX51VZ, UX51VZA, and UX51VZH. The serial number of this machine is D5N0CY845932229 and comes up as a "UX51VZ-DB103P" when checked on this ASUS website. All of the bioses can be found at this ASUS website.
            1) Do I have the correct bios or should it be the v205 for UX51VZ? Is there something I can check inside the machine to make sure?
            03-31-2024, 11:56 PM
