HPDMI unable to add SN after flashing BIOS
  • pappyN4
    • Aug 2020
    • 5
    Hi all
    I have an old HP Mini 1000 series netbook that I occasionally still use. I got a newer wifi card upgrade from an old junk laptop that was being tossed. I had to update the BIOS with a modded one to bypass a wifi whitelist check.
    Windows itself works ok, but when I try to add the model/SN/etc... with HPBQ193 (NbDmiFit_1.14B.zip USB boot with DOS) it does not save it to the EEPROM. The ESCD.dat file is created, says its saved, but as soon as you exit the app and start hpbq again all the info is gone.
    I dont know the policy of linking to other sites, but the bios-mod file I flashed is:
    361A0F15_NWL_ByCamiloml
    Any ideas?
    • 22279
    Re: HPDMI unable to add SN after flashing BIOS
    Post your original bios .
    • pappyN4
      • Aug 2020
      • 5
      Here's backup of original.
      It's older 361A0 F12 version so missing some bug fixes compared to F15 and will not boot with 104 error due to new wifi card.
      model:HP Mini 1137NR
      SKU:NM119UA#ABA
      CTO:ABA
      serial:CNU.....FX
      • pappyN4
        • Aug 2020
        • 5
        Comparing the two BIOSes in hexplorer. In the original, the only place I see the serial number/SKU mentioned is in a little island of text starting at position ec000h in a huge sea of "FF". While ec000h in the NWL modded bios is all FF at the position. Would copying that block of text over to that position work?
        • pappyN4
          • Aug 2020
          • 5
          So to answer my own question in case it helps someone else. Yes
          Copied over block from ec000 and ec800 and flashing it restored back logo and hardware info.
          • kenkaniff
            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
            by kenkaniff
            Product Name: HP Pro x360 Fortis 11-inch G9
            System BIOS: U94 Ver.01.08.00 10/06/2023
            Serial Number: 5CG31946F5
            SKU Number: 85W05EC#AK8
            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
            I needed to remove bios password...
            10-01-2025, 04:32 AM
          • helpmepleasethanks
            Thinkpad T440P bios repair after WIFI whitelist mod
            by helpmepleasethanks
            As per the the rules, here are the specifications of my laptop :
            • Make and model number : Thinkpad T440P
            • Serial number (S/N) : PB-03A7V7
            • Model type - Model (MTM) : 20AW-S2N800
            • Bios version : 2.50 (not 100% sure, that's what I remember)
            Here is the problem, and the events leading to it :
            1. Upgrade screen, keyboard, trackpad, RAM and CPU
            2. Reboot and use the laptop for a bit : everything is working fine
            3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
            4. Boot up the device : bios warning, as expected
            5. Shutdown the device again (no power)
            6. Connect the 8-pin clip of a CH341a
            01-09-2025, 12:09 PM
          • bql
            In search of advice for flashing bios via efi shell
            by bql
            Hi Badcaps,
            I'm having the same Notebook and problem as in this topic:
            HTML Code:
            https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/3601016-need-bios-for-clevo-pd50pnp
            I'm assuming that flashing the provided bios in this topic would solve my problem.
            The only thing i can boot to is EFI shell
            How do i flash the bios image in the EFI shell ? / Can i use any flash.nsh or is the executable interconnected to the bios image? ( i cannot find any bios related files in the internet...
            11-26-2025, 05:21 PM
          • istvanszasz99
            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
            by istvanszasz99
            Product ID: RZ09-0421
            Motherboard: CH580
            Bios File Size: 32,768 KB
            Dear Forum Readers!
            !!! MY RAZER BLADE...
            11-24-2025, 05:52 PM
          • Timeeez
            X270 - Bios flashing help
            by Timeeez
            I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
            Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
            11-30-2022, 05:17 PM
