Surface 4 Pro BIOS locked
  • salim.thebadboy
    • Aug 2016
    • 51
    • belguim
    hi guys
    it is an urgent request can any body delete the password from the backup
    thanks in advance
    Last edited by SMDFlea; 03-25-2023, 06:27 AM. Reason: Attachments cleanup,server space low.
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: Microsoft Surface Pro 4 clean bios backup
    Originally posted by salim.thebadboy
    hi guys
    thanks in advance
    try this..
    • salim.thebadboy
      • Aug 2016
      • 51
      • belguim
      thanks a loooot bro
      this make my day
      • neoblink
        • May 2017
        • españa
        Hola buenas tengo es mismo problema puedo pasarles el bios corrupto?
        • imranromi
          • Jan 2015
          • 1290
          • Pakistan
          Try this and reply.
          • vnn567
            Banned
            • Sep 2017
            • 11
            • usa
            How to dump bios surface pro 4
            help me
            IT IS VERY SMALL
            • imranromi
              • Jan 2015
              • 1290
              • Pakistan
              help me
              IT IS VERY SMALL
              what do you need?
              • Gords
                • Sep 2017
                • 7
                Microsoft Surface Pro 4 UEFI Password Request
                Thanks to a kind forum member here i managed to get a dump of my bios and am now looking for password removal if possible. was unable to dump all regions and i suspect the regions i couldn't dump have the password information but maybe im thinking too negatively lol. BIOS and DESC regions dumped along with a txt dump of FPT -i for bios information.
                Thanks in advance for any help.
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  Re: Microsoft Surface Pro 4 UEFI Password Request
                  Try this...
                  cmd administrator ..
                  use fpt.exe -f xxxxxx.bin -BIOS
                  if you find error (ex. error 150) due to protected bios, try to hibernate mode first before you execute...
                  goodluck
                  • Gords
                    • Sep 2017
                    • 7
                    Error 368: Failed to disable write protection for the BIOS space.
                    Just as you anticipated. Im unable to try Hibernate as no OS will boot with the bios locked. The only entry i have is Recovery Console, currently using win 8.1 as FPT didnt like windows 10 much. Im unsure if i can boot an installed os manually.
                    For now i shall try and see if i can get a windows to go usb to boot and if it does work ill try the hibernate trick.
                    Any suggestions
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      Any suggestions
                      check this,
                      https://support.microsoft.com/en-us/...m-a-usb-device
                      Surface Studio, Surface Book, Surface Pro 4, or Surface Pro 3 without a configured boot order in UEFI
                      Shut down your Surface.
                      Insert the bootable USB drive into the USB port on your Surface.
                      Press and hold the volume-down button on Surface.
                      While holding down the volume-down button, press and release the power button.
                      Follow the on-screen instructions to boot from your USB drive.
                      have you try above??
                      • Gords
                        • Sep 2017
                        • 7
                        Yes thats how i boot from usb to use recovery console on a windows install usb.
                        The bios password has some kind of protection active that stops any windows BCD working apart from the original.
                        I can maybe also boot any kind of recovery disk just not an OS.
                        I hope that makes sense?
                        • Gords
                          • Sep 2017
                          • 7
                          Would i be right in thinking that there is absolutely no way around this now and i have to remove and flash the chip directly?
                          Thanks.
                          • zaleon
                            • Dec 2017
                            • 5
                            • US
                            Hey, I'm a noob here, but it sounds like some others have had the same problem I'm having. I have a Surface Pro 4 and can't get into the UEFI BIOS settings due to a forgotten password. I can boot into Windows 10 just fine but can't make changes to the UEFI settings.
                            Would flashing one of these "clean" BIOSes fix that problem? If so, how do you go about flashing it manually? I've downloaded a few of them but they all seem to be of varying sizes, but the majority are 16,384KB. However, even this is significantly larger than the official Microsoft firmware package I downloaded that shows 3,843KB in size.
                            I have the Surface Pro 4 with Intel M3 and 4GB of RAM if that makes a difference.
                            Any help would be greatly appreciated!
                            • zaleon
                              • Dec 2017
                              • 5
                              • US
                              Microsoft Surface Pro 4 UEFI Unlock Request
                              Can someone please take a look at my BIOS dump for my Surface Pro 4 and see if they can remove the password?
                              I dumped it using the FPTW64 -d bios.bin -BIOS command, so hopefully that is correct.
                              Thanks!
                              • imranromi
                                • Jan 2015
                                • 1290
                                • Pakistan
                                Re: Microsoft Surface Pro 4 UEFI Unlock Request
                                Originally posted by zaleon
                                hello,
                                can someone please take a look at my bios dump for my surface pro 4 and see if they can remove the password?
                                I dumped it using the fptw64 -d bios.bin -bios command, so hopefully that is correct.
                                Thanks!
                                no the bios is corrupt i think this board bios chip size 16mb you send 10mb.read and save again.
                                • zaleon
                                  • Dec 2017
                                  • 5
                                  • US
                                  Hi imranromi, thanks for your reply. I've been trying all day but the FPT program refuses to output more than the 10240kb as shown in the attached screenshot. FPT reads the total size of the BIOS as 16384kb as you say but when I run the dump command it just not pulling all of it.
                                  I've also been unable to find another BIOS backup tool that works on Windows 10 and the Surface Pro 4.
                                  Any ideas?
                                  • imranromi
                                    • Jan 2015
                                    • 1290
                                    • Pakistan
                                    If you remove bios password open laptop find bios chip and use bios programmer read and bkup upload the file. I try remove inside the bios file password.when bkup bios 16mb file need.
                                    • rioreno
                                      • Feb 2009
                                      • 540
                                      • Indonesia
                                      Thanks!
                                      1. To get fulldump 16mb ,try without -BIOS : FPTW64 -d bios.bin
                                      2. To makesure your 10mb dump can be flashing back with FPTW without failed.. please trying flash back your dump... if it successfully flashing back with FPTW , i"ll remove the password from your 10mb
                                      • zaleon
                                        • Dec 2017
                                        • 5
                                        • US
                                        Hi, thanks for your reply. I have tried without the -BIOS before and it complained it couldn't read that flash area or something to that affect.
                                        I believe after writing to another member here with the same issue, that iamromroni is correct and the only way to get the full dump is to open up the tablet and read it using a physical programmer.
                                        However, the Surface Pro 4 from what I've read is extremely difficult and time-consuming to get into without damaging it, so I'm not willing to go that far as long as my Windows is still working. I appreciate your assistance in trying to resolve this issue. This is a great forum!
                                        • FalconPunch
                                          Surface Pro X 1876 Bios corrupted
                                          by FalconPunch
                                          Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                          Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                          08-09-2025, 03:56 AM
                                        • HighSkai
                                          Surface Laptop 5 Locked Bios Password
                                          by HighSkai
                                          Hi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
                                          Surface Laptop 5 - 15 in. i7/16/256
                                          Serial number:
                                          0F01D7E23283FB
                                          Thanks!​
                                          06-30-2024, 01:53 PM
                                        • Cosmin Adrian
                                          Surface go 2 locked bios
                                          by Cosmin Adrian
                                          Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
                                          Intel ME Version: v11.8, Build 4494, Hotfix 94
                                          Product Name: Surface Go 2
                                          Product Version: 1
                                          Product Serial Number: 023875311051
                                          UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
                                          SKU Number: Surface_Go_2_1927
                                          Family: Surface​...
                                          03-03-2024, 12:48 PM
                                        • muhuruu
                                          Surface pro 4 bios request
                                          by muhuruu
                                          Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
                                          01-22-2024, 05:38 AM
                                          Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-06-2024, 08:10 PM
