Surface 4 Pro BIOS locked
  • Ghamidi
    • Mar 2020
    • 303
    • France
    #61
    How can remove BIOS password Surface pro 4
    Hello
    how can remove password microsoft surface pro 4 from bin file with HXD or
    Winhex
    Can someone explain the method ? Thank you
    • Motherboard Repairs
      • May 2019
      • 63
      • United Kingdom
      #62
      Microsoft Surface Pro 4 (1703) UEFI Password
      I am having difficulty unlocking surface book/pro tablets i have tried one byte in different areas plus other methods no luck.
      Here is a bios dump i have tried to crack but no luck, if any one here can try.
        • May 2019
        • 63
        • United Kingdom
        #63
        Re: Microsoft Surface Pro 4 (1703) UEFI Password
        Managed to remove password but now it takes 30 seconds to boot tried to cleanme bios but no luck, any help will be appreciated thanks
          • 20339
          Try this bios.
            • May 2019
            • 63
            • United Kingdom
            #65
            Originally posted by SMDFlea
            Try this bios.
            Thanks bios dump works, i need to check where i am going wrong thanks again
              • 20339
              Can you describe what software and method you were using to clean the ME firmware .
              • hosoi
                • Jul 2020
                • 30
                Re: Surface Pro 4 - UEFI password removal please?
                [QUOTE=mattpd;943828]YES! Thank you.
                Touch works, starts up fast, and no more BIOS password.
                Can you tell me how you did it?
                EDIT: I ran it though hex compare. The only difference between the two files are a single character at offset 00606620. Is that all it takes?[/QUOTE
                hello, can you please tell me how did you flashed that bios to clean the password ?
                thanks
                • jangut4
                  • Aug 2020
                  • 3
                  Hello, i bought the Tablet 2 years ago on eBay, since then the bios is locked by a password. I have seen some people here that are able to retrieve the password by a bios dump. I dumped the bios with "Universal BIOS Backup Toolkit 2.0" since the Intel FPT returned "Error 361, Protected Range Registers are currently set by BIOS..."
                  Im asking since my battery is dead anyways and i would like to unlock it in the progress of changing the battery, so i would have physical access to the bios chip aswell
                  Greetings from Germany
                  • RethoricalCheese
                    • Mar 2013
                    • 1516
                    • Estonia
                    #69
                    Re: Surface 4 Pro BIOS locked
                    You need physical access on pro 4. Unlocking using software is for Pro 3.
                    • jangut4
                      • Aug 2020
                      • 3
                      isnt the chip WSON tho?
                      Also is there no way doing it by Software? I have the ability to write custom kernel drivers aswell as efi drivers
                      • RethoricalCheese
                        • Mar 2013
                        • 1516
                        • Estonia
                        #71
                        You can read and modify (part of) your bios but you can't write it back to bios chip. That's the issue. On pro 3 there is a way to decrypt the password so no writing is needed.
                        Yes, it's a wson8 chip so you need to unsolder it first.
                        • keczuk
                          • Dec 2019
                          • 83
                          • WWW
                          #72
                          Surface 4 PRO i7 - bios pwd - please remove
                          Please remove pwd from my dump.
                          • RethoricalCheese
                            • Mar 2013
                            • 1516
                            • Estonia
                            #73
                            Re: Surface 4 PRO i7 - bios pwd - please remove
                            This
                            • keczuk
                              • Dec 2019
                              • 83
                              • WWW
                              #74
                              thanks
                              • ifra_red
                                • Apr 2014
                                • 5
                                • philippines
                                #75
                                surface pro 4 bios locked
                                help me remove bios password of my bin file please
                                • peste
                                  • Dec 2016
                                  • 12274
                                  • ROMANIA
                                  #76
                                  Re: surface pro 4 bios locked
                                  try..
                                  • ifra_red
                                    • Apr 2014
                                    • 5
                                    • philippines
                                    #77
                                    Originally posted by peste
                                    try..
                                    won't work there still the same
                                    • peste
                                      • Dec 2016
                                      • 12274
                                      • ROMANIA
                                      #78
                                      try this.
                                      • ifra_red
                                        • Apr 2014
                                        • 5
                                        • philippines
                                        #79
                                        try this.
                                        its fixed sir. many thanks to you
                                        i've already flash it with another firmware but the touch won't work
                                        after flashing with the one that you gave was all working .
                                        • lweas
                                          • Dec 2020
                                          • 8
                                          • pakistan
                                          #80
                                          Hi there i have extensiively read almost all of your replies relating to SP4.
                                          I myself also have a SP4 bitlocker plus UEFI locked, i was wondering is it possible to decrypt the UEFI pass without desoldering as in the case with SP3?
                                          No need to remove thee password just getting the old one is enough.
                                          And if not and i desolder and send you the dump and you do manage to remove the pass, will i lose my Serial and other data in the UEFI menu?
                                          your reply is much appreiated O wise one.
                                          • HighSkai
                                            Surface Laptop 5 Locked Bios Password
                                            by HighSkai
                                            Hi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
                                            Surface Laptop 5 - 15 in. i7/16/256
                                            Serial number:
                                            0F01D7E23283FB
                                            Thanks!​
                                            06-30-2024, 01:53 PM
                                          • Cosmin Adrian
                                            Surface go 2 locked bios
                                            by Cosmin Adrian
                                            Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
                                            Intel ME Version: v11.8, Build 4494, Hotfix 94
                                            Product Name: Surface Go 2
                                            Product Version: 1
                                            Product Serial Number: 023875311051
                                            UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
                                            SKU Number: Surface_Go_2_1927
                                            Family: Surface​...
                                            03-03-2024, 12:48 PM
                                          • muhuruu
                                            Surface pro 4 bios request
                                            by muhuruu
                                            Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
                                            01-22-2024, 05:38 AM
                                            Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-06-2024, 08:10 PM
                                            Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
