Surface 4 Pro BIOS locked
  • lweas
    • Dec 2020
    • 8
    • pakistan
    #81
    Re: Surface Pro 4 - UEFI password removal please?
    Originally posted by RethoricalCheese
    Yes, that's all it takes. The tricky part is knowing the exact byte to modify
    can you tell what byte to modify?
    replacing what with what? (the byte at the offset 00606620)
    Your help will be much appreciated.
    • lweas
      • Dec 2020
      • 8
      • pakistan
      #82
      i have a SP4 i7 6th gen 8gb 256gb model.
      • peste
        • 12258
        • ROMANIA
        #83
        Re: Surface 4 Pro BIOS locked
        Originally posted by lweas
        Hi there i have extensiively read almost all of your replies relating to SP4.
        I myself also have a SP4 bitlocker plus UEFI locked, i was wondering is it possible to decrypt the UEFI pass without desoldering as in the case with SP3?
        No need to remove thee password just getting the old one is enough.
        And if not and i desolder and send you the dump and you do manage to remove the pass, will i lose my Serial and other data in the UEFI menu?
        your reply is much appreiated O wise one.
        post the bios, and someone will help you..nothing of the bios information is lost ..
        • RethoricalCheese
          • Mar 2013
          • 1514
          • Estonia
          #84
          If you really did read my posts, I have said multiple times that surface pro 4 password cant be decrypted.
          Only one byte is modified, which disables the password, thus no serials or other information is lost (I don't consider it an unlock if theres any information lost besides password/security settings)
          • lweas
            • Dec 2020
            • 8
            • pakistan
            #85
            yes i did read many of your contributions and i do understand it can't be decrypted as of yet.
            But does disabling it allow to reset it to some new password? Removing the old one completely in the process.
            As of now i am stuck in a training institute will be sent home on 20th January will send you the BIOS dump then.
            Can you guide on how to understand BIOS and learning what to modify what not to modify?
            Your help uptill now has been greatly appreciated Thankyou.
            • lweas
              • Dec 2020
              • 8
              • pakistan
              #86
              Re: Surface 4 PRO i7 - bios pwd - please remove
              Originally posted by keczuk
              thanks
              is your model surface pro 4 i7 8gb 256gb?
              I have lost my BIOS+CHIP broken so i am looking for same model one.
              • lweas
                • Dec 2020
                • 8
                • pakistan
                #87
                This
                here it is labelled old.zip
                Hope it works out
                • RethoricalCheese
                  • Mar 2013
                  • 1514
                  • Estonia
                  #88
                  Hope it works out
                  Here you go.
                  • lweas
                    • Dec 2020
                    • 8
                    • pakistan
                    #89
                    Here you go.
                    ThankYou its unlocked but no matter what i do it does not Boot from the USB, i tried fresh windows10 downloaded iso, i tried backup from recovery media i even tried to boot into UBUNTU live media but no such luck.
                    Any Ideas?
                    • rRob
                      • Jan 2021
                      • 7
                      Any Ideas?
                      Is your Secure Boot turned off ?
                      Did you try using Rufus to create a bootable USB with GPT and UEFI options ?
                      • skylurler46
                        • Feb 2021
                        • Bahrain
                        #91
                        Re: Microsoft Surface Pro 3 UEFI password
                        Dear Forum,
                        I bought a surface pro 4 from eBay and got ripped off by the seller since it has a BIOS/UEFI lock. I tried to get a dump of the BIOS using the FPTW64, but I get the error:
                        Error 316: Protected Range Registers are currently set by BIOS, preventing flash access.
                        I used the Intel CSME System Tools v11 r30 for this Surface Pro model.
                        Can you help me out please on how to get the BIOS dump? So that I can share it here over here and hopefully, you can help me out with the password?
                        Thanks again.
                        • skylurler46
                          • Feb 2021
                          • Bahrain
                          #92
                          Originally posted by jangut4
                          Hello, i bought the Tablet 2 years ago on eBay, since then the bios is locked by a password. I have seen some people here that are able to retrieve the password by a bios dump. I dumped the bios with "Universal BIOS Backup Toolkit 2.0" since the Intel FPT returned "Error 361, Protected Range Registers are currently set by BIOS..."
                          Im asking since my battery is dead anyways and i would like to unlock it in the progress of changing the battery, so i would have physical access to the bios chip aswell
                          Greetings from Germany
                          I have a similar issue. Has there been any update to this issue? Any resolutions?
                            • 20318
                            Read through this thread again.
                            1. It will not work using FPT ,you will need to desolder the bios chip.
                            2. The chip is WSON8 so you will need an adapter,there are cheap ones on aliexpress/ebay.
                            Once you have the bios post it here and someone will fix it, or your other option is to send it back for a refund as it is not as described / not working. Ebay has a good return policy.
                            • skylurler46
                              • Feb 2021
                              • Bahrain
                              #94
                              Thank you so much for your speedy response!
                              The FPT was bit easier, but I understand it is not the solution for SP4.
                              Plus I tried here in my location for people who can work with electronics, but they refused citing that they don't/never worked with Surface devices .
                              I guess I have to hope that eBay helps me with the refund!
                              Thanks once again for the advice!
                              • vadik1533
                                • Mar 2021
                                • uk
                                #95
                                Re: Microsoft Surface Pro 4 (1703) UEFI Password
                                Originally posted by SMDFlea
                                Try this bios.
                                this bios file is good for surface 5 1796? as I'm looking for bios file to re-write and remove the UEFI password
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1514
                                  • Estonia
                                  #96
                                  You would need to read and modify your own bios.
                                  • rado777
                                    • Mar 2021
                                    • Ukraine
                                    #97
                                    Re: Microsoft Surface Pro 4 clean bios backup
                                    Hello
                                    Im a new user here and want to ask for some help
                                    Could anybody help me to remove uefi password from backup,and explain what Microsoft Surface tab 4 pro clearme bios doing?
                                    Thx in advance
                                    • peste
                                      • 12258
                                      • ROMANIA
                                      #98
                                      Originally posted by rado777
                                      Hello
                                      Thx in advance
                                      try..
                                      https://www.badcaps.net/forum/showthread.php?t=88533
                                      • alihomee
                                        • Dec 2012
                                        • 1565
                                        • malaysia
                                        #99
                                        microsoft surface pro 4
                                        file got password ......looking for password removel
                                        • peste
                                          • 12258
                                          • ROMANIA
                                          #100
                                          Re: microsoft surface pro 4
                                          try..
                                          • HighSkai
                                            Surface Laptop 5 Locked Bios Password
                                            by HighSkai
                                            Hi, can someone help me with unlocking the bios password on my bios locked Microsoft Surface Laptop 5
                                            Surface Laptop 5 - 15 in. i7/16/256
                                            Serial number:
                                            0F01D7E23283FB
                                            Thanks!​
                                            06-30-2024, 01:53 PM
                                          • Cosmin Adrian
                                            Surface go 2 locked bios
                                            by Cosmin Adrian
                                            Hi guys! So i bought a used Surface Go 2 and it came with a password locked bios.I really wanna remove the lock because they disabled USB booting and disabled SD card which is really weird. I read the forums about the ME tools and fptw but i just cant find one that works for my version of ME. Thanks in advance!
                                            Intel ME Version: v11.8, Build 4494, Hotfix 94
                                            Product Name: Surface Go 2
                                            Product Version: 1
                                            Product Serial Number: 023875311051
                                            UUID: {5C754E9E-0971-4B86-9221-C7D877AED9CD}
                                            SKU Number: Surface_Go_2_1927
                                            Family: Surface​...
                                            03-03-2024, 12:48 PM
                                          • muhuruu
                                            Surface pro 4 bios request
                                            by muhuruu
                                            Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
                                            01-22-2024, 05:38 AM
                                            Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-06-2024, 08:10 PM
